Can't get the draining screw out it is totally stucj
SOURCE: no steam comes out of iron
Hi, there is probably a something broken in the moulded plastic trigger assembly (there is a plastic broken finger that actuates a micro-switch under the rubber handle cover). If you are so inclined, use an orange stick and gently pry up the rubber handle cover on either side from the front to the rear cord end to access, inspect and troubleshoot. I am in SoCal and use the California Electric website to obtain parts or go to the Rowenta home website to locate useful manual information, PDF reader and dealer near you.
SOURCE: tefal proline express steam generator iron needs de scaling
Make a solution of half water and half white vinegar. Fill up your iron and get it good and hot then let it sit a couple hours. flush out and repeat as necessary. Hope you find this helpful. Please give me a fixya rating If this works for you. It works very well as long as it is not completely filled with scale. Once you have it good and clean By a gallon of bottled water at the market and use that for your Iron and you will never have a scale problem again. I learned how to do this 20 years ago from a 80 year old woman from england. If it is really bad you can up the vinegar concentration but do not go higher than 2 cup to 1.
George
SOURCE: I have a Swan S15040 steam generator iron, the
I had same issue , now , once you turn the unit on , you should see displayed 3 steam jets and the flashing standby , turn the dial on the iron to max ,press the steam button on the machine to max steam , leave for a minute or so , now press the steam button on the iron , does it make a noise ? if it does , slightly raise the whole front end of the unit ( easier if you have the iron on the worktop and not on the unit !) for a minute then try and press the steam button on the iron again . I think there is a bit of an issue about the conection between the water tank and the filter . This solved my issues and i do hope it will help you .
SOURCE: I have a Bosch Steam
Your steam generator my have mineral deposits that are clogging the steam openings. One of the easiest things to do is to pour out the water and add white vinegar. Let the vinegar sit for about 2 hours. Then turn on the iron and press the steam button until the deposits are loosened and flushed by the heat and steaming vinegar. Do this on a towel or other absorbent fabric so you don't stain your ironing board. You may need to unplug the iron, let it cool and then gently **** the steam vents with a wooden skewer or toothpick.
I hope this helps you. If it does, please rate my suggestion!
SOURCE: The iron heats up, but when the steam generator
Chemicals and minerals in the water have probably clogged the vents. Empty the water. Pour 1/2 cup WHITE vinegar into the reservoir. Turn on your iron and let it heat. Then press the steam generator button several times until the vinegar is gone. Unplug the iron. As it is cooling, take acotton swab and gently wipe the surface of the vents. You can probe GENTLY with the swab, but don't push it into the vent or the cotton head may get stuck.
As you're pressing the steam button, keep the iron in the ironing position, not standing. If the vinegar just will not come out of the vents, use a wooden toothpick to loosen the build up.
This always works well for me and I hope it does for you.
If so, please come back to Fixya and rate my advice!
