Question about HP LaserJet 4730 MFP Printer
Reset the NVRAM should fix the problem. Get the NVRAM reset procedures from HP support site or Google them. Regards, Mike
Posted on Apr 07, 2016
resetting your scanner
1. Turn off your scanner, and then turn it on again.
2. Insert a pointed object into the reset hole on the back
of the scanner. Then, gently press and release the reset
button. Pressing reset does not clear the scanner's
working memory or the V-Scanner folders.
If this doesn't work here's step two! CAUTION. THIS WILL ERASE EVERYTHING, but it MAY Fix the Problem!!
Initializing your scanner clears all information stored in your
scanner's working memory. Initialize your scanner only when
you are sure it is not working properly. V-Scanner memory is
not affected when you initialize the scanner.
1. Turn off the scanner, and turn it on again. First, the DSP
boot version, and then Welcome To Digital Trunking appears.
2. Press 0. The following messages appear on the display:
System Tests
Select Test
Exits if no
Key Press
3. Press 1. The following messages appear on the display:
Factory Init
Erase Memory
ENTER if Yes
CL to EXIT
4. Press ENT. The following messages appear on the display:
Initializing
Clr Main Mem
V-Scan is OK
Please Wait
5. Do not turn off your scanner until the initialization is
complete. When the initialization is complete, M000 and
Bank 0 Ch 00 appear on the display.
If that doesn't help. Please get it serviced. I do recommend to get a DSP Firmware Update for it. The download is free from RadioShack but the cable and software is not.
I hope this helps and solves this problem.
btw.. if you don't have the product manual http://support.radioshack.com/manuals/ome20-496.pdf
You will need Adobe reader or equivalent!!
Happy Scanning!!
Jan 21, 2013 | Radio Shack Pro-2096 Base Scanner
Nov 20, 2012 | Radio Shack Pro-96 Scanner
Jan 22, 2012 | Radio Shack Pro-2096 Base Scanner
Jul 09, 2011 | HP LaserJet 2840 Printer
Jul 08, 2011 | HP LaserJet M1005 Printer
Apr 11, 2011 | Radio Shack Pro-2096 Base Scanner
Jun 23, 2010 | Radio Shack Pro-2096 Base Scanner
Feb 19, 2010 | Radio Shack Pro-95 Handheld Scanner
Jan 23, 2010 | Radio Shack Pro-95 Handheld Scanner
Jan 12, 2010 | Radio Shack Pro-2096 Base Scanner
Sep 13, 2013 | HP LaserJet 4730 MFP Printer
270 people viewed this question
plz ansewer
