Question about Toshiba DKT-2020 Corded Phone
Change name on LCD display
I can't seem to get into the name display information.  I have the booklet and so changed the display keys from "Soft Key Off" to "Soft Key On"; then the directions say to Press a [DN] + #621--then the current info. should appear and the you can change it with the dialpad. (Page 43 of the user guide)  Instead when I push Line 1 (which is our main line) I get a dialtone and when I push #621 I get a busy signal.  Am I doing something wrong?
Posted by TracyC on
  • TracyC Nov 01, 2007
    It is dark gray/almost black but there is not a "punch down box" next to it. It is connected directly to the wall phone outlet.  Looks like we acquired it in 2005 refurbished. Obviously the name display information worked once, because the name on it is the secretary that was here 2 years ago.
  • marshb Nov 06, 2007
    Tracy, I have a refurbished Toshiba DK-16 system with some 20 button and some 10 button phones. I changed the time by typing the following on the main phone. (It MUST be the main phone or it won't work.) Hit the button for Intercom (the lowest on the bottom left on my phone system 20 button phone), then 652, enter the time in military time using two digits each for the hour, minutes & seconds, then hit the redial, & the spkr button to finish & it should have the right time. [email protected]
Anonymous
    Novelist:
  • 201 Answers
The Toshiba phone you have can work on a few different Toshiba phone systems that program differently. Before I can look up the correct information to help you I will need to know which Toshiba phone system you have. Someone at the office should know but you can also track down the phone system and get a part number or other identifiable markings from it. Older Toshiba systems were typically a light gray color and the more phones you have the bigger it will be. The newer systems are usually dark gray (almost black) there will be a lot of wires going in and out of it and most likely a punch down block or two right next to it (white, about 12" tall, 3" wide, with hundreds of small metal pins to connect wires to.)
Posted on Nov 01, 2007
  • Anonymous Nov 01, 2007
    It sounds like you are talking about a phone. There is a main control unit (KSU) that all your phones connect to, it does not look at all like a phone. It will have a lot of wires running into it or at least several very fat wires. We have to figure out which Toshiba phone system you have before trying to make programming changes. It should say "Toshiba" on the front cover along with a description or part number, example: "Toshiba Strata CTX100"
    BTW, the rating system here is not explained very well. A rating of "Thanks for Trying" or below actually hurts the people that are trying to help you.
How do you change the display names on the Avaya 5420.
hi robert.
see if this helps you,if not go to the link and the bottom.
How to change the display name in Avaya phone? Press the Select soft key or the OK button or the right arrow key. Use the up and down arrow keys to scroll the display to the option Display Name. Press the Change soft key to change the setting or use the left or right arrow keys. Display your extension number and the date and time on the phone when it is idle.
Display Name - Avaya
marketingtools.avaya.com/knowledgebase/user/ipoffice/.../1408/display_name.htm Search for: How to change the display name in Avaya phone?
How do you change the display names on the Avaya 5420 Google Search
Nov 03, 2017 | Avaya Lands Phones
I am trying to change the names that appear on my phones i.e. people who have left but names still appearing
To change the names in the telephone system you'll need to enter programming.
Programming is done on 7310, 7324 and 7316 type sets.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow).
The display should now ask for an extension number.
Enter extension number you want to change the name on.
Press the show key (top right arrow)
The display should say LINE ACCESS
Press the next key (bottom right arrow) .
The display should say CAPABILITIES.
The display say Name.
press the Chng soft key.
use the dial pad to enter the name. advance using the arrow soft key to go to the next letter
ex. Bill = 2,2 -> 4,4,4 -> 5,5,5 -> 5,5,5
Press the next key (bottom right arrow) to enter the name.
Press the release key when finished
Jan 19, 2011 | NorStar BCM-T7208 Corded Phone
Can't change name on phone? the screen that pops up reads "terminals&sets" and I "set" to change a certain line. Show set is displayed. I type in the number that the name needs to...
It sounds like your in the right area, you just need to go a little farther into that sets programming.
when you enter in the persons extension number press the show key (top right arrow)
Dec 22, 2010 | NorStar M7324 Telephone
I need to know how to change the name that shows up with each extension and how to access the voicemail if you do not have the previous users password?
I'm guessing that your looking to change the name on the telephone system and not the voice mail.
The password on the mailbox that you don't know the password to will need to be reset to access that mailbox. While in admin programming you can change the name on the mailbox.
To reset your voice mail password,on press feature 983 the screen should say log:
enter 1020000 (default password) if you have a 3 digit intercom number, 120000 if you have a 2 digit intercom number
the display should say mbox, AA, and othr above the three soft keys
press the mbox soft key
the screen should say add, del, and chng above the soft keys
press the chng soft key
enter in the mailbox number you wish to reset the password on
press ok
the screen should say reset and next above the soft keys
press the reset soft key
If you pres the next soft key 2 or 3 more times you'll come to the name of the mailbox press Chng and enter in the new name (the # key advances by a space and pressing # twice puts the comma to separate the first and last name press ok when finished
press the Rls key
your password will be reset to 0000
Dec 08, 2010 | NorStar T7316E Corded Phone
How do I change the name on the display for the Nortel T7316e?
To chane the name on the sets you'll need to enter telephone programming.
Sep 01, 2010 | NorStar T7316E Corded Phone
How can I change a name on a display screen for the telephone model M7310?
Aug 20, 2010 | NorStar Meridian M7310 Phone
Station name
The display should now ask for an extension number. Enter extension number you want to change the name on.
press the Chng soft key. (or the clear key to erase)
Jan 20, 2010 | NorStar T7316E Corded Phone
How do i change the names that are on the display on a Nortel 7316e
Programming2.gif is done on 7310, 7324 and 7316 type sets.Enter programming2.gif by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming2.gif.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you want to change the name on.
Oct 16, 2009 | Nortel T7316E 2-Line Corded Phone
How do I change the name that is displayed on my M7208 Meridian Telephone.
Sep 30, 2009 | Lands Phones
Toshiba DKT-2020 Corded Phone Logo
525 people viewed this question
Top Toshiba Lands Phones Experts
martin hogg
Marvin
Marvin
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
