Minolta QMS PagePro 9100 Laser Printer Logo
A
Anonymous Posted on Apr 03, 2014
Upper output been full - Minolta QMS PagePro 9100 Laser Printer
Tareq Bin Mostaq Mostaq
Level 3:
President:
  • Minolta Master 1,449 Answers
  • Posted on Jul 23, 2014
Minolta Master
Level 3:
President:
Answers
1449
Questions
31
Helped
614567
Points
3628
Upper sensor displace or broken
Output tray full
Please tell me the model no.
Hp 9050 laser jet stacker error
Probably just a bad sensor or dirty sensor causing the issue.
Stacker or stacker/stapler output bins
For the 3,000-sheet stacker or 3,000-sheet stacker/stapler, the output bins are the upper bin (face-up) and the lower bin (face-down).
The upper bin (face-up) is the top bin on the stacker or stacker/stapler. This bin holds up to 100 sheets of paper in face-up order as they exit the printer. A sensor causes the product to stop when the bin is full. Product operation continues when you empty or reduce the amount of paper in the bin.
Lower bin (face-down) is the lower bin on the stacker or stacker/stapler. This bin holds up to 500 sheets of paper and can stack or staple jobs. This bin is the default output bin.
BBRAKE LINES IN AND OUT OF THE ABS CONTROLERrake line routing
Upper Left-Left Front Output
• Upper Middle-Right Front Output
• Upper Right-Rear Output
• Lower Left-Master Cylinder Secondary/Front Input
• Lower Right-Master Cylinder Primary/Front Input
1helpful
Hp 5550n error - standard output bin full please remove all paper from bin
After print paper reaches upper bin, you can observe a flag moving while paper coming out. once this flag is stopped moving printer treates bin full..check the flag is moving freely. open top cover clean this sensor.
My Canon DR 7580 has image void in the front image. Looks like two void columns. The Image reader is clean. Can the upper and lower imager be swapped to see if the problem is the upper imager?
You cannot swap upper and lower images. You can scan the page twice (in duplex mode) by reversing the same. Ensure which side is giving perfect output.
DR 7580 is a CONTACT scanner and hence the paper has to touch the glass surface properly. There are two full sized rollers, just above/below the scanning module, which does this job. Ensure that they are proper and there is enough pressure, press and release 3-4 times to check it is stuck.
S. Mohan, Chennai, India
Konica minolta pagepro 9100 laser print Error message upper output bin full
check the sensor. for the upper output pin. it mite need to be replaced.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Upper output bin full cual es la solucion a este error?
check the sensor it mite be dirty
1helpful
How can compress picture in mswords2007
FORMAT->>on the left in upper corner chose compress pictures, click on it window will pup up, chose what you like in target output. And that is it.
Optra S2455 output bin control
I used the Optra W810 driver. It had listing for *UPPER and *LOWER for the bins....
So..I took a chance on the following
Output Bin
Sel Cmd Description
1 3 Output Bin 1
2 4 Output Bin 2
*LOWER 2 Lower Output Bin
*UPPER 1 Upper Output Bin
3 5 Output Bin 3
All is goo!
CL7000 copier/printer problem
hi im jules_09,there must be a small piece of paper stocked at the output tray.see if you can open the front door then full out the fusing unit somtimes paper is stocked in it.then while the fuser or fusing unit is out check the output tray if there is a paper.in the fuser unit check the hotroller or upper roller its a black metal roller that heats up
Top Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Daniel Blask
Daniel Blask
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
