Question about Taylor 7506 Precision Tech Lithium Battery Electronic Glass/Chrome Scale
I changed the battery. If I tap it it shows 00.0. When I stand on it it says - - - -ines
Tried to reset DMPBD79last step it shut off it wouldnt turn back on I just get a blinking redlight.
This is for a diff. model but give it a try, they may be diff. #'s showing up then what pops up on screen then is listed below.
  1. Remove any disc from the drive and switch the device to stand-by
  2. Press and hold [OK], [BLUE] and [YELLOW] simultaneously on the remote control until the device turns on and shows "00 RET" on the display
  3. Repeatedly press [RIGHT] on the remote control until the device shows "08 FIN" on the display
  4. Press and hold [OK] on the remote control for at least 3 seconds -> The device will reset itself to factory condition and show "HELLO" on the display
  5. Press [POWER] button on the remote control -> The device will shut down
May 02, 2016 | Panasonic Televison & Video
Code error 00-00-00 30-00-28
If the lens got stuck, you have a problem. It can be caused by many things. A broken sprocket, a broken gear, just a little dent in the lens barrel, dried out grease and many other things. Even a defective motor or just a bad contact or a broken connection can be the cause. Non of them can be repaired by yourself. Sometimes, tapping the camera on the palm of your hand, could solve the problem (temporarily), but don't bump it to hard, or you could damage it beyond repair. Tap it with the lens barrel down ward, asif you want to tap it out. But only in a few occasions it really would work. If the battery has enough power, to switch the camera on, pulling it through a setup and displaying the error message, the battery should not be the cause. Getting out the battery and replacing it after a few moments, could reset the error, so i tries again to switch on normal. But if the error keeps coming back, I think it is wise to start saving for a new camera. Most camera's on the market now, perform better and will cost a fraction of what you paid a couple of years ago.
Oct 28, 2014 | Cameras
Changing in a stand up walker
Hello. From my research, the only thing that would change it from a sit-and-play to stand up walker would be to slide the foot rest out of the way. This video was helpful. It shows a baby using it standing up. Hope this helps.http://www.youtube.com/watch?v=CIRRYrlO4Lw&feature=related
Enjoy your little one while he/she is still little.
Blessings. And if that doesn't work, here is the contact infor for Combi.
Corporate Address
Combi USA, Inc.3520 Westinghouse Blvd., Suite BCharlotte, NC 28273
TelephonePhone: 704-697-1690Fax: 704-697-1695Toll Free: 800-992-6624
Hours of OperationMonday - Thursday:8:30 AM - 4:00 PMFriday:8:30 AM - 1:30 PM
Feb 22, 2012 | Combi All- in-One Activity Walker
How to set time
Turn on your TomTom:
1. Tap the screen
2. Tap Change Preferences
3.Tap Arrow to go to page 3
4. Tap Set Clock
5. Select your choice of 3 options
a. 18:00
b. 6:00pm
c. 6:00
If this helps you, please vote, thank you!!
Jul 07, 2011 | Tomtom ONE XL GPS
Ineed product key for (MICROSOFT OFFICE 2007 X12 30263) Sl.No-61 46 9e cb 00 04 00 00 00 65
Hi atomar1985,
I see that you need assistance with you Microsoft Office 2007 product key.
It should have come with the packaging of you Office 2007 Disc, if you dp mpt have that anymore that will be a prob, you can always try calling Microsoft forfurther details regarding your product since it was probably registered online when you installed it the first time you had it.
But then again if you really can't find the packaging and Microsoft will not be an option regarding this query you try what goggle can provide if you just search for it.
check this link http://www.rafayhackingarticles.net/2010/07/free-microsoft-office-2007-product-key.html maybe this can help you out to make you Office 2007 work again.
I hope that this Helps regarding your concern.
Have a nice day.
mvincentc
May 25, 2011 | Computers & Internet
Changing the language
Tap on 'Start > Settings' (it is represented by a gray gear in front of an yellow folder. It should be the second item, from the bottom to the top, the closest one to the question mark, which stands for Help). Tap the second tab (standing for 'System') and search for an icon representing the Earth (standing for 'Regional Settings'). Tap over it and choose the language that better suits your needs, in the dropdown menu. Tap OK to save and quit.
This procedure won't change the entire ROM to the language you want, of course, but will allow you to better understand what is going on with your device.
Hope you are able to sort your problems out.
Regards,
Carlos
May 09, 2010 | HTC Touch Viva Cell Phone
Last week I updated my TomTom One with the latest maps, etc. Since then whenever I use my TomTom it keeps displaying a "Shutting down in 10 seconds" screen, with follow up screens, and then it shuts down....
Make sure you have "never turn off screen" checked, To do this tap "change prferences" tap the forward arrow until you see "battery saving preferences". Tap "battery saving preferences" then tap "never turn screen off". Tap "done" and make sure that "switch off when external power is lost" is not checked. Tap "done". If you do not see this option go back into "change preferences" tap the forward arrow until you see "show menu options" it should read "show fewer munu options"
Sep 26, 2009 | Tomtom One XL GPS Receiver
Ineed to change my tomtom from a foreign language to english
Turn your TomTom on and tap the map screen, tap the wrench, then tap the forward arrow until you see a icon of flags, tap the flag icon and then change your language.
Dec 13, 2008 | Tomtom ONE GPS Receiver
Removal of stand
There are 5 screws in the back of the TV, immediately above the stand. From the stand, they are at the 10:00, 11:00, 12:00, 1:00, and 2:00 locations. If you remove the screw, and find a washer with the screw, then it's probably the right one. Once all 5 screws are removed, the stand slides right off the bottom. Unfortunately, once the stand is removed, the opening is left in the bottom. It's not too bad since once it's mounted to the wall, it's not high enough to see the bottom of the TV anyway. Good luck!
Aug 09, 2008 | Toshiba REGZA 47HL167 TV
Change am to pm.
  • Tap the screen to bring up the menu
  • Tap the 'Change preferences' icon
  • Tap the arrow right to the icon 'Set clock'
  • Choose how to display the time (18:00 , 6:00pm , 6:00)
  • Set the time (You can also tap 'Sync' to synchronise time with your PC)
Jun 13, 2008 | Tomtom One XL GPS Receiver
Taylor 7506 Precision Tech Lithium Battery Electronic Glass/Chrome Scale Logo
88 people viewed this question
Top Taylor Health & Beauty Experts
Marvin
Marvin
Are you a Taylor Health and Beauty Expert? Answer questions, earn points and help others
