Question about JVC KD-G110 CD Player
1996 Chevrolet Tahoe
I have recently tried to change the stock radio in my tahoe to a jvc cd player. when i pulled out the old stock unit that didnt work i noticed that the stock connector was gone. so i wired the the new connector to the old wires. i got the factory wiring diagram from a gm dealer.  my problem is that when i was done the cd player worked for about  a minute then it quit. i have power to the unit and it lites up but no sound comes out of the speakers.
Posted by RBKA on
Rufus Pennix
    New Friend:
    Problem Solver:
  • 16 Answers
Re check your wires and make sure none a crossed, if you are using black tape make sure the wires are not poking threw the black tape and touching
Posted on Jun 03, 2013
Anonymous
    Problem Solver:
  • 6 Answers
Exactly a minute after you turned it on it went out, did it go out with like a bang or spark, seriously, this would indicate that the wiring wasn't correct somehow, i know u checked the fuse for the correct ampperage required and the most important question do you have an amp because most aftermarket head units aren't wired for 6 speakers,unlike oem Bose unit which has a built in amp and 6 wires output, you should have rca jacks which requires a amp for the additional output speakers. I could be wrong regrding how many output available on your new head unit.
Chino
Chino
Posted on Mar 11, 2009
How do I find the part number for my 2004 Tahoe Delco radio?
If it's got a CD player,it might be this one ??? Just found one on 'Feebay'..03-05 GM Chevrolet GMC Tahoe Yukon Silverado Radio Cd Player 15104155 JS26209
May 07, 2017 | Cars & Trucks
I can have the volume turned all the way up and its not loud at all. why?
Maybe lots of things maybe blown speakers try to change the fade front to rear check the balance left to right make sure the mute isn't on can you tell what head unit you have? did the radio just start doing this or was it this way when you got the Tahoe?
Jan 12, 2013 | 2003 Chevrolet Tahoe
I am trying to play a cd in my 2007 tahoe. it just gives me optical error messasge ?what could be the problem
try and blow compressed air into the slot if that doesn't help send it out for repair threw a radio shop
Jul 09, 2012 | 2007 Chevrolet Tahoe
My cd player/radio lights, info screen lights, heater/ac light and cigarette lighter stopped working, but the cd player/radio still works on my 2005 Chevy Tahoe....how can i fix this?
sounds like it's a fuse issue even tho the radio works,, my vehicle has a radio fuse and a assessory fuse the controls the lighter and lights on the radio
Apr 08, 2010 | 2005 Chevrolet Tahoe
2004 chevy tahoe cd goes into radio and display
Yeah you need a new CD player common on those trucks but be careful the RDS radios must be programmed if get a used factory radio
Nov 20, 2017 | 2004 Chevrolet Tahoe
Need wiring schematic 1996 chevrolet tahoe
try a couple of things before tracing wires,first check the switch at the pedal,then the ground wires at each tail light
Sep 07, 2009 | 1996 Chevrolet Tahoe
My 2005 tahoe stereo radio still plays but the 6 disc cd player will not play, will not reject CD just keeps saying initializing
Turn the radio off and disconnect the battery. This will reset the radio and cd player, NOTE:' MAKE SURE THE RADIO IS OFF OR YOUR GOING TO BE PROMPT TO ENTER A CODE TO REACTIVATE THE RADIO. Good luck and keep me posted.
Jul 03, 2009 | 2002 Chevrolet Tahoe
Error message for 2001 Tahoe stock CD Player
try using a lens cleaning disk
(what is the error_)?
Dec 29, 2008 | 2001 Chevrolet Tahoe
2004 Chevrolet Tahoe cd player says changer full and won't work
Bad news. Your CD player isn't any good. I work for Chevrolet and this is a very common problem. The magazine inside the radio (the part that holds the cd's) starts going crooked. I think some real tiny springs that hold it break, causing this problem. Only fix is to replace the radio. First try this. Go to the fuse box under the hood and remove the 'Radio' fuse for 1 minute. This may reset the radio. You may be able to eject any cd's stuck in the radio. May be cheaper to put in an after-market radio. Sorry.
Dec 17, 2008 | 2004 Chevrolet Tahoe
JVC KD-G110 CD Player Logo
248 people viewed this question
Top JVC Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Ekse
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
