Lexmark X2470 All-In-One InkJet Printer Logo
Question about Lexmark X2470 All-In-One InkJet Printer
Enable bidirectional communication for a dell 964 printer
5 Related Answers
rjwharris
Harris
  • 102 Answers
SOURCE: what it means Enable Bidirectional Communication caution spam number below
To enable bi directional printing:
Open Printers and Faxes in control Panel
Right Click on the Printers Icon
Select PROPERTIES
In the Properties dialog box select the PORTS tab
Near the bottom there is a check box to enable Bi-directional printing
Make sure it is checked
Click OK to exit the dialog box
Posted on Feb 21, 2009
Anonymous
  • 53 Answers
SOURCE: Lexmark X2500 is giving Bidirectional communication error message
Make sure that the "Enable Bidirectional Support" checkbox is checked: Go to "Control Panel"->Printers->Right click on the print Object->Properties under "Ports" tab, enable this check box if not already enabled. If you using vista make sure you do this from an "Admin" account, you may also need to select the "Run as Administrator" option after you right click on the "PrintObject".
Posted on May 14, 2009
Anonymous
SOURCE: when trying to print says enable bidirectional communication
I came up with a work around solution and for $9.99 I'll tell youo how I did it......
Posted on Jun 22, 2009
Anonymous
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: My Lexmark x5495 will not print. I get the message
    Go to Control Panel > Printers and Faxes > right click on the Lexmark 5400 Series print object > Properties > Lexmark 5400 Series Properties window pops up, click on Ports tab > place a check mark in Enable bidirectional support by clicking in the box beside it. Hit Apply and click Ok to save the settings. Try to print. If problem persists, disconnect the printer usb cable from computer, uninstall the software completely by clicking on Windows logo Start menu > All Programs > Lexmark 5400 Series folder > Tools > Uninstall. Restart pc. To reinstalI, I recommend you use the software you can download from the Lexmark website. Just click on this link: http://bit.ly/cgn74X. Download and install the software. Follow the instructions. Try to print again. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
    Posted on May 04, 2010
    Anonymous
    • 3344 Answers
      Verified Fixya Pro
      SOURCE: how do I enable the
      Follow these steps:
      • Go to Printers and Faxes(XP)/ Printers(Vista and Windows 7) in Control Panel. Right click on the Lexmark 5600 Series print object and click on Properties(note: image below is just an example).
      • In the Properties window, go to Ports tab.
      • Enable the bidirectional support as shown in the image below(must have a check mark). Hit Apply then OK to save the settings.
      If bidirectional support option is grayed out or cannot be enabled, problem may need further troubleshooting. Contact Lexmark technical support for further assistance. Thank you for choosing Lexmark.
      Posted on Sep 15, 2010
      2helpful
      Trying to print to a dell photo aio printer 964 from my laptop and it keeps telling me "communication not available; the printer cannot communicate with the computer; please turn on enable...
      Bidirectional Printing - A means of printing by a computer printer which prints one line from left to right, then the following line from right to left. Such printing is faster than printing in one direction only, as there is no need to wait for the carriage or other imaging mechanism to return to the left margin before starting a line.
      how to enable bi-directional printing.here's how:
      1. -click on start
      2. -click on printers and faxes (control panel->printers and faxes)
      3. -right-click on Dell Photo All in One Printer 964 All-In-One icon
      4. - click on properties
      5. -click on ports tab
      6. -down at the bottom there's a small box before bi-directional support
      7. -tick the box to enable it then click apply,ok
      8. -try printing again
      note: in vista , printers and faxes is printers.in win 7 ,it's devices and printers.
      and properties in win 7 is printer properties
      2answers
      Keeps telling me to enable bidirectional communication
      Hi:
      When you first loaded the print driver there should have been a box to check to enable bidirectional communication. Most Lexmark printers require this to work properly
      Andrew.
      How do I Enable bidirectional communication on a dell 924 printer? Thanks
      Go to Start
      Control Panel
      Printers
      Right click on your printer, left click Properties, left click Ports.
      Make sure to check the box Enable Bidirectional Support. (Enable Biodirectional Support)
      CANT ENABLE BIDIRECTIONAL COMMUNICATION X4550
      I have tried to set up this wireless printer on my laptop (windows vista basic). I run through installation and get message - installation complete and the green indicator light is fully on. When I try and print I get message Printer cannot communicate with computer - please turn on 'Enable Biodirectional Communication' in printer properties. I go to control panel/printer/propertie/ports/ and I see Enable Biodirectional communication - the box is grayed out and I cannot enable it. Any suggestions?
      When i go to print i get an error message saying that i need to enable bidirectional communication. How do i do this?
      Enable Bidirectional Support Go to Start
      Control Panel
      Printers
      I am unable to "enable bidirectional communication" with my AIO 966
      Is it connected via a parallel port? If so, then you need to change the parallel port type in your computer's BIOS Setup to EPP or ECP type; Windows will register the new port type and you should be able to establish a bi-di connection.
      BTW, does it not work without this bi-directional connection? The only thing you lose is some fancy stuff like ink levels monitoring etc.
      When trying to print says enable bidirectional communication
      8helpful
      2answers
      72helpful
      2answers
      What it means Enable Bidirectional Communication caution spam number below
      Select PROPERTIES
      Top Lexmark Office Equipment & Supplies Experts
      Clive
      Clive
      Marvin
      Marvin
      Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
