Question about Boating
Sounds like the fuel pump isn't working, you can buy service kits though quite often corrosion will prevent you from removing the valves.. or it could simply be the fuel cap isn't venting, remove fuel cap and see if the engine continues to run!
Posted on Apr 28, 2017
SOURCE: 1991 Johnsoon 90 HP outboard hard to start, floods after stop
Hi, You did a good job of assessing the problem. It sounds like the float valve in the carb is the likely problem. This would overfill the carb when sitting, flooding the engine and the pressure in the bulb pump would go down as the fuel leaked out. Float valve should be investigated and that should Fixya!
Posted on Mar 13, 2009
Jun 13, 2018 | Mercury Boating
Feb 26, 2016 | Seloc Mercury Outboard Repair Manual, 1965...
Nov 01, 2014 | Seloc Mercury Outboard ONLY, 40-115HP...
Aug 31, 2014 | Mercury Impeller, Water Pump - for...
Aug 24, 2014 | Seloc Mercury Outboard Engine Repair...
Jul 18, 2014 | Seloc Mercury Outboard Repair Manual, 1965...
Jul 18, 2013 | Seloc Mercury Outboard Repair Manual, 1965...
May 11, 2012 | Seloc Mercury Outboard Engine Repair...
736 people viewed this question
