Question about Ice-O-Matic ICEU220HA Undercounter Ice Machine
Ice machine won't fill with water - Ice-O-Matic ICEU220HA Undercounter Ice Machine
Beto Flores
    New Friend:
  • 102 Answers
Make water supply is on if you have a water filter in place it may be clogged or if unit has a float valve youmay has trash in the line clogging it up
Posted on Apr 24, 2014
Lg in door ice maker, water won't fill in ice tray
I had that problem and water was also leaking. I tossed the ice and kept the door open for about 20 minutes when the door open alarm started to go off. It's working again. The error code on the door was 1f
Feb 01, 2013 | LG LFX25960ST Stainless Steel French Door...
Scotsman icemaker dce33 is making ice, but it is melting
Yes it could and also check dump valve it should not let water through during freeze cycle.
Oct 03, 2012 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Hoshizaki km-900mah ice maker won't start the freeze process
cycle is, fill cycle for 1 minute first. If there is not water entering the unit when first turned on, look for that issue. Water turned off, water valve not working or some restriction, clogged water filters, etc. That is got to happen first. Don't over look the bin stat being bad. Nothing happens if teh bin stat is bad. It sends voltage to the control board that runs the unit.
Jul 28, 2012 | Hoshizaki Freezer Commercial Ice Machines...
Tfx20r ice maker won't fill
Try this fill the ice maker with tap water so we can decide if it is the ice maker or the water control valve. After the water freezes if the ice dumps and the ice maker does not refill with water then you will need to replace the=> WR57X10033 Water Control Valve If the ice maker does nothing after being filled with tap water and the water freezes then this would point to the=> WR30X10093 Ice Maker Assembly If you have questions I will be here to answer them for you, Thanks, Sea Breeze
Jul 06, 2012 | Refrigerators
GE TFX24E side by side refrigerator, ice maker won't fill with water.
Hi, I have a GE TFX24E refrigerator. The ice maker is not filling with water. I replaced teh water valve with no joy. If I pour a cup of water into the dispenser the ice maker will freeze and harvest the ice. Any ideas? Is there a replaceable water fill sensor?
Sep 03, 2011 | GE WR30X10093 Refrigerator Icemaker Kit
Ice tray won"t fill with
Ice maker stopped making ice. For this problem you have check few things. First thing, is the water filling in the ice maker chamber and then ice maker not making ice? Or, the water is not filling in the ice maker chamber so it's not making ice. If the water is not filling in the ice maker chamber then it's clear that ice is not getting made due to no water in the chamber. For no water filling, the problem is either water supply valve turned off so water is not filling. Turn on the water supply and it will fill. But if the water supply is turned on then the other possibility is ice blockage in the water fill tube. There is a tube from which the water runs and enters the ice maker chamber. If this tube is blocked then water will not enter the chamber. The tube needs to be defrosted, by using hair dryer. This procedure melts the ice collected in the tube and water starts running again. But if water fill tube is completely clear and no ice blockage or any other blockage. Then other possibility is water valve at the back of ice maker unit. This water valve is for letting the water in the ice maker. The water valve open only for 7 seconds and in this time the water fills in the ice maker chamber and then water valve closes and the same procedure runs again in the next water filling cycle.------- For your information I will mention that there are two valves. One is the main valve the back of the fridge section. This main valve lets the water enter the refrigerator and other valve is at the back of ice-maker section. This other valve lets the water to enter the ice maker. In most of the cases the fault is water valve at the back of ice maker section. ------------- The other above possibilities which I gave you is water not filling in ice-maker chamber so it's not making ice. But now consider that water is filling in ice maker chamber but it's still not making ice. Then the problem is ice maker unit itself. This unit is controlled by main board. But in most cases if water is filling the ice maker but it's not making ice then its faulty ice maker unit. So see if the problem is water not entering the ice maker then the water fill tube is frosted by ice or the water valve at the back of ice maker is faulty. Replace the valve. ------------
You can get required parts from sears part direct online site or from repairclinic.com site.
This will help. Thanks. Helpmech.
Apr 26, 2011 | GALAXY Microsystems 25.4 cu. ft....
Ice machine does not fill reservoir does not fill
Is there a water filter on the system? also the line might be clogged from the inlet to reservior
Jun 13, 2009 | Scotsman Ice Maker 600LB CM3 30inW...
Hoshizaki KM-1600S too much water supply
If water is standing in the bin the drain is clogged. If water is raining down into the bin, Machine may not be level or the drain on the ice machine maybe partially clogged. If machine freezes up water will rain into bin too. Water fills ice machine while in harvest and continues to fill until ice machine`s suction reaches 49 degrees and the defrost timer times out.(usually 1-3 minutes after suction line reaches 49 degrees)
Jan 16, 2009 | Hoshizaki KM-1600S Stackable Crescent...
Ice cube shape
hoshizakis make ice cubes depending on the amount of water in the sump. if you are starving for water the sump only partially fills in the fill time allowed . then it makes ice until the water is used up and the float switch drops and the cubes are little slices. you can adjust the size of cubes you want by raising or lowering the float assembley in the sump. if its to low the water rises and the float rises and tells the machine you happy with little slices. if you raise it up to max height you can max fill before float satisfies and max ice cubes. But if you are starving for water the time to fill will run out before the sump fills and cubes will be small no matter where you set the floats assembly. water starving can be due to crud in the water line, to small a water line, most hoshizes take a half inch line ,or a clogged water filter. if you suspect a filter take it out . if fill is drastically improved you need a new filter. be aware that starving for water on a hoshizaki will eventually lead to broken evap plates. big time expensive.good luck. i put in a new machine ruined by starving water and the new one made little chips of ice real quick. i finally pulled the filter out and voila! big cubes and great production.
Oct 28, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Ice-O-Matic ICEU220HA Undercounter Ice Machine Logo
378 people viewed this question
Top Ice Kitchen Appliances - Others Experts
Dennis
NOEL
NOEL
Are you an Ice Kitchen Appliances - Other Expert? Answer questions, earn points and help others
