Cannon MG 5220 printer code 5100 printer error turned off an the problem continued
Usually an error 5100 code is saying that the ink carriage has problems. Usually something currently is or recently hammed the cartridge carriage. With the machine turned off and the power cord unplugged, open the machine and inspect the inside do you see any stray pieces of paper along the paper's usually route?
There is a way to reset the machine to clear out the error. I would need to know the exact model of your Canon.
for more help visit CBR Tech Solutions
SOURCE: Cannon mx 310 error 5100 Says chck printr with alarm light flashi
heres the problem from service manual: error 5100, a error occured in your encoder signal, it list 4 things in the serice manual.
carriage unit. carriage motor, logic board, timing **** film.
ok my first thing i would look at is the film that runs directly behind the print head i would think it is dirty. just turn on printer and get print head to the middle and turn off machine, gentle move print head to one side and gentle clean the film strip with a cloth with a little metho on it, move print head to other side and clean other part of ****.
i reckon that will fix your problem its a common problem they tend to get a bit of grease on the timming ****.
Canon Tech
SOURCE: error 5100
- Carriage unit
- Timing **** strip film
- Logic board ***'y
- Carriage motor problem
SOURCE: cannon pixma mp510 ~ error code 5100 help
Error 5100 is Carriage error.Possible problems in:
- Carriage unit
- Logic board assembly
- Carriage motor
First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.If this not help your printer need service.
SOURCE: what is error message 5100 for this printer?
Code 5100 refers to a carriage that is not freely moving from side to side. Look to the far left and right for anything that would impede the carriage path.
Also, it is possible that the clear plastic encoder strip just behind the carriage path has become smudged with (most often) grease. You can clean the strip with a cotton swab dibbed in alcohol.
I hope this helps!
