Intermatic Malibu LV-115M1
SOURCE: My Intermatic Timer (model PB115M1) is not keeping
...may have solved this one... opened up an Intermatic Model HB31R and it seems to have the WG2030 timer motor... this model (complete timer box) cost $20 or so...
SOURCE: where to but a malibu
I do not have a resource for that timer.
No internet source shows that timer, and I research timers each day.
If I find something, I will update this post.
Work-around:
If power pack timer stopped working, buy cheap plug-in timer and put power pack on override and plug power pack into cheap timer. Power packs come with 5-year limited warranty. Otherwise there are no replacement clock motors for this product.
Intermatic PB series timers show on following 2 links:
http://www.poolandspacontrols.com/products/compact%20timer%20mechanisms/electronic%20timer%20mechanisms.aspx
http://www.poolandspacontrols.com/products/compact%20timer%20mechanisms/mechanical%20timer%20mechanisms.aspx
http://waterheatertimer.org/Woods-timers-and-manuals.html#FM1D
You posted under Malibu, which sells Intermatic ML series power packs.
http://waterheatertimer.org/Intermatic-trippers-and parts.html
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
http://www.intermatic.com/products/professional%20lighting/light%20expressions/power%20packs.aspx
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
SOURCE: want to know how to set the timer intermatic
Following page has instructions and troubleshoot you might find valuable. Including photo of tripper installation.
To
set ML series power pack that has analog dial, place trippers on dial at times
you want timer to turn on-off. Dial has hours showing with dark
background for nighttime. To set current time, rotate dial clockwise two
revolutions and then line up current time with arrowhead located on
inner dial. Manual override switch is round knob located upper left of
dial.
Upvote the help.
And take advantage of fixya expert assistance live.
SOURCE: What timer motor fits in Intermatic ML121RT Power Pack ?
The PB912M10 timer clock motor is not sold separately. Aug 2010.
If power pack transformer still works: buy cheap plug-in timer, set
power pack to override, and plug power pack into cheap timer.
With receipt, power pack might still be under warranty.
Open following link for power pack tips and resources:
