Question about Zynga Facebook Apps
Will not go to county fair..it sticks,cant do anything on the farm.it,s stuck.. fix it..
Colin Gray
  • 96 Answers
Try updating the version of Flash installed, these games mostly don't load if it's outdated. Also clear your browser cache regularly.
Posted on Apr 05, 2014
The dehumidifier will not turn off, even after the thermostat is disconnected. It is not a thermostat problem. How do I fix?
More than likely the contact points in the unit contactor are pitted and stuck together. When the control voltage is removed by the satisfied thermostat, the stuck contacts will not allow the system to shut off.
A tap with the handle of a screwdriver will usually jostle the stuck contacts loose....but they will stick together again fairly soon. The control more than likely needs to be replaced.
Unless you are fairly comfortable around exposed electrical wiring, it is recommended that you call a competent service technician.
Sep 19, 2015 | Heating & Cooling
Can anyone remove old rusty farm equipment and haul it to a salvage yard?
I WOULD CALL A SCRAP YARD COMPANY, THEY SHOULD MOVE IT FOR FREE.
Jun 17, 2015 | Cars & Trucks
How do i separate the old glass from the convertible top on a 2010 mustang
Glass is bonded to top cloth. You must replace entire rear cloth section and sew it to the top. Requires top removal and upholstery sewing machine. Farm this job out.
Jun 16, 2015 | 2010 Ford Mustang
How do you get rid of gnats outside in the yard?
No category for this, I'd contact your local farm county agent, who may have an insect control pamphlet.
Mar 17, 2015 | Refrigerators
Is the Topaz Solar Farm story about a real construction in California
Located on the northwestern corner of the Carrisa Plains, the 550 megawatt Topaz Solar Farm will produce sufficient electricity to power 160,000 average California homes. The Topaz location was selected after an extensive review of potential sites in California which considered the available solar resource, proximity to existing electrical transmission lines, current land uses, and environmental sensitivities.
Economic benefits include an estimated $417 million in positive impacts, including property and sales tax revenues for the County, wages from direct and indirect employment, induced spending and supply chain revenues.
Dec 07, 2014 | Cars & Trucks
Farm pro raider(Homier)
Only thing left is compression. Stuck valves will affect compression as well as worn rings.
Jan 23, 2014 | Peg Perego John Deere Farm Tractor and...
Problems with farmville 2
I`m on stage 28 going on 29 in Farmville 2 i never gotten any farm cash since stage 20 can you help me
Jun 26, 2013 | Zynga iPhone Apps
Clucth gets stuck cant find dip stick
Nothing in a bottle will fix anything,common sense
A clutch issue or any problem,needs to be diagnosed
& properly repaired,no other why,not the genie in a bottle
I will say, that those products keep Morgan Lucas top fuel
dragster running, as well as other motor sports racers.
Jun 01, 2012 | 1994 Ford Escort
I NEED CODE TO COUNTY FAIR
which county fair is it and how many #'s does it need because because you dont need stuff thats free from the county fair deal with paying it
Jul 23, 2009 | Compaq Computers & Internet
Facebook Apps Logo
41 people viewed this question
Top Zynga Facebook Apps Experts
 Grubhead
Grubhead
Vincent G
Vincent G
Andrew Taylor
Andrew Taylor
Are you a Zynga Facebook App Expert? Answer questions, earn points and help others
