Question about Belkin F8E836-USB-MOB Mouse
Belkin Optical Mouse
Good morning.  I bought a belkin optical mouse model F8E836-USB-MOB but I need the drivers for Windows Vista.  I am not really sure if it exist.  Please, let me know.
Posted by Bladimir on
  • Anonymous Nov 05, 2007
    cannot install
  • Anonymous Nov 17, 2008
    Same
Anonymous
In control panel device manager, select the device and attempt to re-install the driver from a list of compatible drivers - select HID Compatible Mouse as opposed to USB Browser Mouse
Posted on Nov 18, 2008
Anonymous
I'm in same trouble.
Posted on Aug 06, 2008
I bought a "mini wireless
First check to see if it is windows compatible and for which version. If windows vista is a comptabile version then you are good to go. For drivers, if windows does not reconize the hardware and cannot install it automatically then yes a driver is needed, normally in this kind of stuff like mouse and keyboard it usually plug and play and windows should easily reconize it unless it was built for mac.
For a wireless mouse, it should come with a usb thumb transmitter and the mouse itself. Under the mouse should be a button that you need to press in order for the computer to reconzie it. Turn on your computer with the usb thumb adapter (transmitter) plug in, then under the mouse or somewhere on the mouse, there should be a button, ( small button) press this button and then see if mouse work. If a manual was provided, please look it over. If mouse don't work, then you got a bad transmitter, and will need to return this to back to the store if it's still under return deadline
Jan 29, 2011 | Computers & Internet
My mouse isn't working its not the batteries because i just changed them and i plugged the usb thing in and i pressed the two buttons to connect them but its still not working. it didn't come with any cd...
You can download drivers for the mouse at:
http://www.belkin.com/support/download.asp?lang=1&download=F8E825-USB&mode=
The mouse may or may not work depending on your operating system. I do not know if this mouse is compatible with Windows Vista/7 or 64-bit operating systems.
Aug 02, 2010 | Belkin Mini Wireless Optical Mouse...
I need the drivers: mouse f8e836, windows xp, please!
Belkin gives no support....
Apr 30, 2010 | Belkin F8E836-USB-MOB Mouse
No cd dive to install diver on netbook from cd provided
Drivers are available from here http://en-us-support.belkin.com/app/answers/detail/a_id/3300/kw/F8E825/r_id/166 NOTE - belkin do not have vista or windows 7 drivers - but the device may not need drivers to work on those systems
Apr 10, 2010 | Belkin F8E825 USB Mini Wireless Optical...
No response from curser when usb is plugged in
Restart the computer using the keyboard "Windows key" and leave the mouse plugged in the USB port. If it has a driver CD, install the software and drivers then restart the computer. Windows Xp should find the new device and make it ready for use. If you are using Windows Vista then you will need to go into your "My Computer" and then "Control Panel" and "Printers and other hardware" and then "Mouse" and click "Troubleshoot" If you are using a Laptop or notebook, disable your touchpad first then plug the USB mouse into port
Nov 04, 2009 | Belkin WIRELESS OPTICAL Mouse
Mouse broke on pc so brought another, and another, but same problem at the end.( found new hardware - unknown device. windows found driver software but encountered a problem installing it) hav now bought 4...
drivers required for mouse operation will be provided in windows itself so u can try connecting your mouse via USB port(except ball mounted mouse)better use optical mouse ...even after this if it is not working then you need to reinstall the OS.
thank you..
Oct 31, 2008 | Computers & Internet
How can I get an upgrade for my wireless mouse?
If your mouse manufacturer does not supply a driver for Vista you are pretty much out of luck for now. Vista is radically different from previous Windows operating systems and some hardware manufacturers are having a hard time adapting to it. If you have to have the mouse I would suggest you switch back to Windows XP till working drivers are released.
Feb 26, 2007 | Belkin F8E825 USB Mini Wireless Optical...
Belkin F8E836-USB-MOB Mouse Logo
738 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Ekse
Jeffrey Groves
Jeffrey Groves
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
