The photocopier starts when switched on and gives an error code E000007-0000 and stop.at first it was showing that it had a paper jam. After the jam was solved, now it started to give the error code E000007-0000 after initializing and it doesn't e me to proceed. What could be the possible cause and the solution
SOURCE: canon copier NP 6412
It is a older copier, it could be a fan is not working, is it making noise. It may be failing......
SOURCE: about error code
cannon ir 5000 copier give me error e 0061 & e0069 what the problem and the solution
SOURCE: canon image runner COPIER
We finally found all the buttons-levers to push and to pull and were able to remove the paper that caused the paper jam. Thanks for your help Nellie
SOURCE: my canon image runner 2230
try this solution: enter service mode by pressing *(additional function) then2 and 8 together and then again * select copier on screen>function>clear>error>ok. turn off the machine and re-start.
