Dishnetwork remotes/setup step by step for tv1 & tv2 during install
No problem just need to know proper way too program dish remotes &remote addresses during installs.
Posted by slickstreet on
  • patricke123 Sep 19, 2009
    my remote control doesn't control the tv what can i do please?
1 Related Answer
Anonymous
  • 56 Answers
SOURCE: In single mode, my remote for TV1 works, but in
Your shared view is enabled. , press the menu button, then option 6 then option 2, disable shared view then select done. ( this can only be done in single mode) then go back to dual mode.
Posted on Nov 12, 2009
Umm my tv2 remote isn't connecting to my reciever so i tried to change the remote address and it doesn't work
Hi my nameis Mike Houston of DISH Network and I see your TV2 remote isn't connecting toyour receiver. You will want to make sure you're at the TV1 location to programthe remote for TV2, press the Menu button 2 times and you will see the SystemInfo screen. On the bottom for the screen you will see the remote address forTV2, make sure the TV2 remote has fresh batteries inside. On the back of thereceiver their will be a Remote Antenna port and you want to make sure that ishand tight. Push and release the SAT button and press record and you should seethe address change for TV2. I will send a link to help with these steps; http://www.dishnetwork.com/SupportSection/remote-control.
Jul 30, 2011 | DISH Network 322 DTV Receiver
When I change the channel on tv2, it also changes the channel on tv1. I have changed the address for tv2's remote, but it still changes tv1's channel.
Hi my nameis Mike Houston of DISH Network and I see your TV2 changes TV1 as well, thereis an easy fix to this problem. You will want to make sure the receiver is inDual Mode and then make sure the TV2 connection on the back of the receiver isin the right port. I will send a link to help with these steps, http://www.dishnetwork.com/SupportSection/same-video-2-tvs.I will leave my e-mail if you have any questions [email protected]
May 22, 2011 | DISH Network DVR-625 DTV Receiver /...
DIDN'T TAKE THE SELECT BOTTON TO WATCH TV AN MY 2ND TV.
Hi, Cheri Torres with DISH Network Customer Service here. I came across your post and wanted to see if I could help. The first troubleshooting step you are going to want to try is making sure the remote is in SAT mode you can insure this by pressing the SAT button once the remote. If the remote is in SAT mode and still not functioning properly you may want to try replacing the batteries if you already have not. If both options do not work for you then you are going to need to try readdressing the remote to your DISH receiver box. I will list here for you the instructions on readdressing your TV2 remote. I hope you find this information useful and if you have any further questions or concerns feel free to email me at [email protected]
Instructions for addressing remote to DISH receiver
  1. First you will want to take your TV2 remote to your TV1 location where the DISH receiver box is.
  2. Go to System Info screen. You can do this by pressing the system info button on the front of the receiver or pressing the menu button twice on the TV1 remote.
  3. Once you are in the system info screen you will see primary remote address (TV1) and secondary remote address (TV2).
  4. Hold down the SAT button until all mode lights light up.
  5. Enter a number between 1 and 15 using the numeric keypad on the remote.Change the number in the little white square to something different than what is already listed for secondary remote address.
  6. Press the pound (#) button.
  7. Once the SAT button blinks three times, press record. Note: If successful, the number selected in step 5 will appear in the System Info screen under Remote Address.
Mar 09, 2011 | DISH Network IR Remote Control
My remote control for tv #2 does not respond and i want to know what to do. i bought a new one what should i do
Hi there, Cheri Torres with DISH Network Customer Service here. I came across your post and wanted to see if I could help. If the old remote was not responding to your TV2 anymore you may want to try replacing the batteries first if that does not work the next step would be to try readdressing the remote to the receiver. You can try readdressing both remotes to get them to work with your DISH receiver box. I will list the instructions for readdressing your TV2 remote here for you. I hope you find these instructions useful and if you have any other questions or concerns feel free to email directly at [email protected]
Instructions for addressing the remote to the receiver
  1. Take your TV2 remote to your receiver box location.
  2. Go to System Info screen.You can do this by pressing the system info button once or by pressing the menu button twice on the TV1 remote.
  5. Enter a number between 1 and 15 using the numeric keypad on the remote.Change the number in the small white square to something other then what is already listed.
Mar 08, 2011 | DISH Network IR Remote Control
Pressed the System wizard button on remote the Sat button lit up for a minute or so then the remote stopped working ! Changed batteries still not working ! reset the box still not working What do I do ??
Hey there, Cheri Torres with DISH Network Customer Service here. It sounds like your remote may need to be readdressed to your DISH receiver. I will list here for you the instructions for addressing your remote to your receiver box. If you are using the TV2 remote make sure you take it to the TV1 location to perform the trouble shooting steps. If you are using TV1 remote stay at the receiver box location. I hope you find these instructions useful and if you have any further questions or concerns feel free to post back here or email me directly at [email protected]
  1. Go to System Info screen. You can do this by pressing the system info button on the front of the receiver box or by pressing the power button once then the channel up button once on the front of the receiver box.
  2. Once you are in the system info screen you will see primary remote address (TV1) and secondary remote address (TV2).
  3. Hold down the SAT button until all mode lights light up.
  4. Enter a number between 1 and 15 using the numeric keypad on the remote.Change the number to something different then what is already listed in the white square.
  5. Press the pound (#) button
  6. Once the SAT button blinks three times, press record. Note: If successful the number selected in step 3 will appear in the System Info screen under Remote Address.
Mar 07, 2011 | DISH Network IR Remote Control
My DVR is recording programs I have not selected and programs that I have recorded are being deleted by User 2 when that TV is not on and the remote is stored in a drawer. I have change the channel for...
Hi, Cheri Torres with DISH Network Customer Service here. Icame across your post recently and wanted to see if I could help. It soundslike your TV2 remote is going to need to be readdressed. It could be possiblethat your TV1 and TV2 remotes are on the same frequency and remote address oryour TV2 remote may be on the same frequency as another remote in a nearby homeor apartment. I would like to list here for you the instructions on changingyour remote address so that it no longer experiences interference. This shouldbe an easy fix for the issue you are experiencing. I hope this works for youbut if it does not or you have any further questions or concerns about thisissue or any others feel free to email me at [email protected] and Iwill be happy to help. :)
Instructions for readdressing TV2 remote
  1. Take TV2 remote to TV1 location (in front of the receiver)
  2. Go to System Info screen. You can do this by either pressing the system info button on the front of the receiver box or by pressing the power button once then the channel up button once on the front of the receiver. (You may need to open the little door on the front right side of the receiver box)
  3. Once you are in the system info screen you will see primary remote address(TV1) and secondary remote address(TV2). For your particular situation you will locate TV2
  5. Enter a number between 1 and 15 using the numeric keypad on the remote.Change the number to something different then what is already listed in the white square.
  7. Once the SAT button blinks three times, press record. Note: If successful the number selected in step 5 will appear in the System Info screen under Remote Address.
Feb 10, 2011 | DISH Network ViP622 DVR DTV Receiver /...
My tv2 only shows one channel on dual mode and i cant change the channel with the remote
Hi billabongwanmy name is Mike Houston of DISH Network and what you will need to do isreprogram the remote. You will need to take the TV2 remote to the TV1 location,on the TV1 remote press the MENU button two times and it will take you to theSystem Info screen. You will then press and release the SAT button and pressthe record button one time on the TV2 remote. I will leave the link to helpwith these steps. http://www.dishnetwork.com/SupportSection/setup-remote
Feb 10, 2011 | DISH Network ViP722 DTV Receiver /...
I lost my control remte for my vip622 but i have the control for de second tv how i program this control?
Hi, Cheri Torres with DISH Network Customer Service here. Icame across your post wanted to see if I could help. The first thing you aregoing to want to check is that you have the correct tab in the front of the TV2remote. If there is a blue TV2 tab in the remote right now you are going towant to take the battery cover off the remote and pull out the blue tab, turnit over and there should be a green TV1 tab on the opposite side, reinsert thetab with the green TV1 tab facing up. I am going to list here for you theinstructions for readdressing the remote to the receiver. Make sure that youare in front of your DISH Network receiver box when you follow these steps. Ihope you find this information useful and if you have any further questions orconcerns feel free to post back here or email me [email protected]
Instructions for addressing your remote to your DISH receiver.
  1. Go to System Info screen. You can do this by either pressing the system info button on the front of the receiver box or by pressing the power button once and the channel up button once on the front of the receiver. You may need to open the little door on the front right side of the receiver to locate the buttons.
  2. Once you are in the system info screen you will see primary remote address(TV1) and secondary remote address(TV2). For your particular situation you will look for primary remote address.
  6. Once the SAT button blinks three times, press record. Note: If successful the number selected in step 4 will appear in the System Info screen under Remote Address.
Feb 04, 2011 | DISH Network IR Remote Control
Cannot get it to work with dish network. It won't accept channel input either!
Hello! If your tv just won't cycle to the correct channel you can change the setting if its tv1 you need a channel scan if it's tv2 try these steps:
http://www.dishnetwork.com/SupportSection/video
Daniel Busa
Dec 31, 2010 | Insignia IS-LCDTV32 32 in. Television
Ok.. the remote has been set to my tv and cuts it on and off. the volume works but when i select the SAT button it does not bring up the menu schedule to browse the channels? The tv I'm trying to figure...
Hey there, Cheri Torres with DISH Network Customer Service.I came across your post recently and wanted to see if I could help. It soundslike your remote is going to need to be readdressed to the DISH Networkreceiver box. You will first need to take your TV2 remote to the TV1 location.I will list here for you the steps on readdressing the DISH Network remotecontrol. I hope you find these instructions useful and if you have any furtherquestions or concerns feel free to post back here or email me at [email protected]:)
Instructions for addressing the remote to the receiver.
  1. Go to System Info screen. You can do this by either pressing the system info button on the front of the receiver box or by pressing the power button then press the channel up button once.
  2. Once you are in the system info screen you will see primary remote address(TV1) and secondary remote address(TV2). For your particular scenario you will want to change the secondary remote address number.
Jan 02, 2010 | DISH Network 135899 Remote Control
Televison & Video Logo
435 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
