Copier My copier shuts off after 5 seconds. the code C04 10 appears with a picture of a wrench. I unplugged the machine in an attempt to reset it. It didn't work.
Posted by frank murphy on
Anonymous
    Problem Solver:
  • 7 Answers
It seems that the machine is Minolta (you haven't menthion the model & brand)
Problem is in exposure lamp, you have to press the reset switch on the main board & check the lamp
Posted on Nov 01, 2007
LG wm2655hva front loader won't stay powered up. Initially showed a PF code, now shows 3 dashes. Power button works for 5 seconds & shuts down machine....
Hey Kemp!
  • Unplug the machine and hold the power button to reset.
  • OR TRY Unplugging the washer for 5 minutes to see if it will reset itself.
  • If NOT, you will have to replace the control board to fix the problem.
Best of Luck!
JP
Jun 08, 2015 | LG Washing Machines
Printer works but gives blank page
Issue: Scans and copies output a blank image Solution: Press ON/OFF switch to reset the multifunction device Reset the device when it is not functioning properly.If the device is not functioning properly or to clear memory, reset it.Important: If resetting the printer's power does not clear the error or return the machine to a functioning state, it may be necessary to attempt a service reset. Click here for instructions to attempt a service reset.On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.) Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.Wait approximately ten seconds and then press the <ON/OFF> button again.Wait until the device has completed its cycling process before submitting another job request.Service Reset:On the operator panel, press and hold the <ON/OFF> button for one second to power off the printer. (The display will go blank.)Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.Confirm the printer is not on and then unplug the power cord from the back of the printer.If the power cord was disconnected (as stated in step 1) in order to shut off the printer, go to step 3.Press the <ON/OFF> button repeatedly five times. Re-connect the power cord.Press the <ON/OFF> button to power the printer back on.Wait until the device has completed its cycling process before submitting another job request.Important:This procedure will not resolve a physical hardware issue. For example, a paper clip is wedged between the paper feed rollers or gears; or, the scanner assembly is detached from the inside housing.This procedure will not resolve all service errors or LCD related anomalies.Service errors appear as four characters (a combination of alpha and numeric codes).
Oct 13, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Canon mx310 error message 5b00
If the device is not functioning properly or to clear memory, reset it. important.gif Important: If resetting the printer's power does not clear the error or return the machine to a functioning state, it may be necessary to attempt a service reset. for instructions to attempt a service reset.
  1. On the operator panel, press and hold the button for one second. (The display will go blank.)
  2. Wait approximately ten seconds and then press the button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
Service Reset:
  1. On the operator panel, press and hold the button for one second to power off the printer. (The display will go blank.)
  2. Confirm the printer is not on and then unplug the power cord from the back of the printer.
  3. Press the button repeatedly five times.
  4. Re-connect the power cord.
  5. Press the button to power the printer back on.
  6. Wait until the device has completed its cycling process before submitting another job request.
    • This procedure will not resolve a physical hardware issue.
    • This procedure will not resolve all service errors or LCD related anomalies.
Aug 27, 2011 | Canon PIXMA MX310 All-In-One Printer
On digital screen of copier code sc555...what is the problem approx. how much to repair?
fuser temperature problem code.IF YOUR MACHINE IS A RICOH,SAVIN.
GESTNER, OR LANIER YOU CAN TRY TO CLEAR IT YOURSELF.PUSH
YELLOW CLEARALL BUTTON THEN ENTER 1,0,7.STOP HOLD THE STOP BUTTON DOWN UNTIL THE SCREEN CHANGES ABOUT 3 SECONDS.PUSH THE ICON BOX THAT SAYS COPIER SP A NEW SCREEN WIIL APPEAR DO NOT TOUCH IT. TURN THE MAIN POWER
SWITCH OFFFOR TEN SECONDS.THE MACHINE WILL ATTEMPT TO
RESET AND WARMUP PROPERLY IF CODE COMES BACK YOU WILL
NEED SERVICE ABOUT 200.00 FOR FIRST HOUR PLUS PARTS IF NEEDED
May 10, 2010 | Office Equipment & Supplies
Red wrench light in on, wont copy- no jams, display shows error, call for help - ricoh aficion 720 copier
first we need to know what is the code.
ex. SC_ _ _
after that we could lock on the problem.
the reset code for this is either off the machine and run SC reset clear/mode (yellow button) 107 press for about 5 seconds cancel button (red button) then exit off machine after 5 seconds on machine
Feb 26, 2010 | Ricoh Aficio 450 Copier
Copier will not operate due to wrench symbol
Hi the the wrench symbol appears when its time for maintenance depending of the type of service needed the copier will shut down, the only why to over come this is to call your service provider for maintenance they will replace what ever parts and or sevice thats needs to be done, they will then enter the code that is need to reset the wrench symbol..
Good Luck
Jan 27, 2009 | Panasonic FP-7735 Black and White Copier
Copier does not operate.
you need to call an engineer. it is a maintenance counter that needs cleared
Jan 27, 2009 | Office Equipment & Supplies
Wrench light on and c7 code appear
C7 is a Fuser Error......The hot part where the paper passes through before exiting the machine is known as the Fuser or Fixing unit etc.
There are 3 parts involved and any of which when they fail will give a C7 error code. The Heating Lamp,Thermisor or Thermal Fuse.
This is a live area of the machine so you wouldnt be advised to attempt a repair without at least a restricted electrical license.
More than likely one of the parts mentioned will need to be replaced and then the C7 error count reset through "08"
May 12, 2008 | Toshiba 1370 Black and White Copier
LOC code flashing on washing machine
Pressing the options and select buttons simultaneously for 5-10 seconds worked. For me it happened this way: on the first attempt, with the indicator lights already "timed-out" and off, pressing and holding the options and select buttons simultaneously for 5-10 seconds caused the lights to come back on and flash the "LOC" code again. But holding the options and select buttons together for 5-10 seconds a second time caused the indicator lights to stop flashing, and allowed me to start the cycle.
Dec 01, 2007 | Frigidaire GLTF2940ES Front Load Washer
79 people viewed this question
Ekse
Marvin
Marvin
