The original relay whose soaked and it didnt worked. it sounded like ''TRRRRRRR'' on a left side on a right it been working fine. after i changed to the new relay right side works fine and flashes on a speedometer but left hand side flashes only 2-3 times then blows the fuse and also flashes ''N'' (neutral.
SOURCE: 2001 aprilia rs125 indicators dont work on left
their sounds like their is a short in the switch or wire.
if i was testing it. id unplug the one side and test the other alone. then each wire individuality for current when i press switch to on position
shorts seem top be visible at times with visual inspection. so look before you touch. and checking the switch for resistance is a good idea also. but do not have the battery hooked up to test switch for resistance or no power to switch when testing.
