Electrical Supplies Logo
B
Bob Trbovich Posted on Apr 02, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I asked this question before, but formulated it badly. I have a LEVITON COMBINATION PILOT LIGHT SWITCH similar to the Model # 5226, but older and not identical. I do not have the original packaging or
Included everything with the summary.
Gil Shultz
Level 3:
  • Master 3,464 Answers
  • Posted on Apr 30, 2014
Gil Shultz
Master
Level 3:
Answers
3464
Questions
Helped
731854
Points
11104
That is cool what is the question and where is the summary?
4 Related Answers
Anonymous
  • 2841 Answers
  • Posted on Jan 06, 2010
SOURCE: I have just installed 2 Leviton decora switch with
This is a single pole light switch and should be wired as any other SP switch. The only difference is that is has a pilot light. All the white neutral wires are tied together and then pushed back in the box with none connected to the switch. The grounds are tied together with a jumper wire connected to the green screw on the switch. That will leave you with 2 or more black wires. If you have just two normally you can connect them to the two screws on the switch and it does not matter which screws. However it may be that with the pilot light you need to connect the wire going to the light to the top screw and the power wire to the bottom or vice versa. Try both ways. If you have more than 2 black wires you need to connect the incoming power black wire and outgoing power black wires together and then jump to one of the screws on the switch. The black wire left over is the black wire going to the light itself. If none of this works then it is obvious the pilot light in the switch is burnt out.
Testimonial: "Thanks a million. I will recheck the wiring tomorrow. Chas"
Anonymous
  • Posted on May 05, 2009
SOURCE: Leviton Single Pole Switch with Pilot Light Model 277W Box
Depends on whether you want the pilot to glow when the circuit is live (the main light is on) or to glow when the circuit is off. (The switch can be used either way, and I have used this switch in both configurations at different places.)
The wiring diagram is on the inside of the box.
In indicates that if you want the pilot light to glow when the circuit is off, then you only need two wires (the live and the return, usually colored black and white, respectively). However, you also need a ground. The instructions say that you need the ground for safety (and probably legal code) reasons, but I suspect that, without the ground, the pilot light won't work in this configuration.
However, if you want the pilot light to glow when the circuit is on, you probably need a three wire configuration (plus the ground).
Hope this helps.
Ottoniel
  • 202 Answers
  • Posted on Mar 15, 2010
SOURCE: I have a leviton 5226 single pole switch with
It's the same as you wire any single pole switch.
A
Anonymous
  • Posted on Aug 24, 2011
SOURCE: Recently installed leviton combination switch was
Pilot light switch is usually rated 15 amp.
Check amp rating of device.
Check volt and watt rating on nameplate of water heater.
4500watt element divided by 240volts = 18.75amps
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html
If you have 120Volt under-counter water heater, then add a comment.
I recommend using contactor to control water heater when using a switch rated for less than 30amp.
Contactor controls water heater. Switch controls contactor.
http://waterheatertimer.org/Ordinary.html
http://waterheatertimer.org/H230A.html
Leviton 5226 want pilot to be on when switch is on. only white, black and ground come to box
If the white wire was previously used as a switch leg then it is not possible to use the device per code requirements.
Light switch outlet
Sounds like you are wiring a combination switch and outlet:
Open following link for illustration:
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#combo
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Recently installed leviton combination switch was working correctly. Now when power is being drawn by the hot water tank it controls the pilot light goes out. Any suggestions or is the switch faulty?...
1helpful
I have a Leviton single pole rocker switch grnd, pilot light back and side wired #5628-2W i am trying to hook it up so light is on when switch is on i have 2 black wires 2 white wires and 1 ground wire how...
easy one first: ground wire to green screw. We have to assume the two black wires are the hot(coming from power source) and switch leg(going to light). Switch will have two brass colored screws. Looking at the switch with the off/on markings right side up. Put hot wire on upper screw and switch leg on other brass screw, With nothing hooked up, the hot wire will be the only wire with voltage on it. You can buy a non-contact voltage tester at Lowes or any place that sells electrical supplies. Now we must assume the two white wires are neutrals(one coming from power source and one going to light. The pilot light part of the switch will either have a silver colored screw or a white pigtail on it. all whites hook together. The pilot light is wired internally to the switch leg. Your switch should work properly now.
2answers
I replaced my old 3way toggle switches with the LEviton 5613 3way lighted rocker switches. Wired exactly the way the older toggle switches were wired. Switches work fine just like the older ones but one...
http://www.leviton.com/OA_HTML/ibeCCtpItmDspRte.jsp?item=4044§ion=10103&minisite=10025
The Leviton page for Leviton 5613 does not have a troubleshoot.
Manual shows simple wiring diagram.
3-way switches will not operate lights if switches are wired incorrectly.
Check your ground wire is connected.
Leviton 5613 series is illuminated.
Check that both switches have 5613 number.
Swap switches and see if problem is inside switch.
I have a 5226 neon switn single pole and how i wired it; i know that the hot wire goes to the jumper side but, is it necessary to fix a neutral wired on the silver screw? Thanks
Yes, but only to operate the neon light. The switch will operate without the neutral. You should have two neutral wires in the box, one in, one out. Besides connecting the IN neutral to the neon light, it must also be connected to the OUT neutral so that your lamp or appliance has a neutral. There might be two silver screws on the switch already connected together for this purpose.
PLEASE SHOW ME THE WIRING DIAGRAM...I THREW IT AWAY BY MISTAKE AND NEED TO DO AN INSTALL.
need constant hot and a neautral plus your load and the rest is self explanatory screws should be color coated blk constant hot copper load silver neautral
1helpful
I have just installed 2 Leviton decora switch with pilot light Leviton 5637-i. The pilot light on both switches are not lighting, the switches operate the light and fan fine. It is wired as shown in the...
Top Leviton Electrical Supplies Experts
john h
Sean Wright
Sean Wright
CJ Rock
CJ Rock
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
