SOURCE: Reset my Cisco AIR-AP1242AG-N-K9 but
Hmmm..., I assume you are using Windows..... Try just going to the Network, see if you router shows up if so.... Click on it... It should ask for a pin type in the pin that usually can be found on the bottom of your router... If not reset to factory defaults and in your broswer type in your IP address, do not use autoconfiguration.... On all Linksys routers the default username is admin (with the password left empty) from there you can set your password and configure your router for use.... Hope this helps ;)
SOURCE: I cannot find the default ip address for Cisco
Hi, The Access Point does NOT have a default ip address
below is quick setup guide to the Access Point
http://www.cisco.com/en/US/docs/wireless/access_point/1240/quick/guide/ap1240qs.html#wp41082
Testimonial: "thanks a lot,i rili apreci8 it.ciao!"
