Stylus is AN11 type.
SOURCE: how do I attach the turntable belt to the Aiwa px e850
Lift the platter off the turntable. You can identify the
motor spindle by using your fingers to turn the round shaft which rotates
freely. Remove the rubber mat off the platter. Place the belt around the outside
of the drum on the bottom of the platter.
From the top of the platter, place your finger in one of the platter
holes and tension the belt so it will not fall off or twist. Griping the
platter trough the holes while keeping tension on the belt place the platter on
the turntable aligning your finger with the belt to the motor spindle. Place the section of the belt on your finger over
the motor spindle. Replace the rubber mat on the platter.
SOURCE: how do i remove the
Hi, grip it at the front edge and pull downward then forward. [email protected]
