Question about IBM ThinkPad R40 2897 Notebook
R40 Thinkpad CD drive
R40 Thinkpad - 4 years old - Windows XP -
CD / DVD player has been working until recently.
PC DOCTOR - does not list DVD as a device
WINDOWS EXPLORER - does not list DVD as a device
CONTROL PANEL / SYSTEM / HARDWARE / DEVICE MANAGER - does not list DVD / CD-ROM DRIVE as a device
Put CD in drive and close door - spins and read light lites - no software player popup on screen appears.
DISK is 95% full - cannot do defrag - not enough space
Fixes Tried:
Running latest files Norton Virus scan now ... do not expect detection
Turned off and reboot - 1 error displayed "Windows Defender... memory location listed with error message"
Rebooted with ACCESS IBM button - does not list CD / DVD player
NEW HARDWARE - ran with "new hardware installed" does not "see" new cd drive.
Hardware or driver problem?
Posted by fixit52 on
  • Anonymous May 17, 2008
    my system cannot read cd or dvd drive.its not showing in the system
  • JAMES JACKSON Sep 09, 2008
    WHEN I GO INTO SETUP TO BOOT FROM THE CD ROM IT IS NOT IN THE LIST HOW CAN I ADD IT SO I CAN BOOT FROM IT JAMES
Anonymous
I also have an IBM R40 with a combo drive that showed the same symptoms. I switched the drive with two another two which I can assure that work 100% correctly, and the same problem happens. First the drive wasn't detected some of the times, or it got randomly "disconnected" while the laptop was on. Nowadays (about 1 year ago), the drive never gets detected, not by the BIOS or by the operating system (Linux, but also tried on Windows), even so, If I don't keep the drive disconnected, when the laptop boots the BIOS hangs for a long time like it was trying to detect the drive, but it doesn't. It turns out that is a system board problem. Hope this helps you on finding the solution. Regards
Posted on Aug 25, 2008
Anonymous
Go into the BIOS and change the startup. Make your cd-rom drive first on the list. You need a Win 9x bootable cd or a Windows XP cd to see if your cd-rom will read the cd. If your system still not not boot of the cd's you might need  a replacement systemboard. It beleve it is not software issue.
Posted on Oct 31, 2007
Anonymous
    Problem Solver:
  • 11 Answers
    Sounds like more of a software problem, I've had my dvd drive only show up as a cd drive but i think that was only in windows 98? Many problems will start showing up when your disk is very full. Try deleting some old files until you have 25% free space (only 75% full) or 20% free (80 full) at the minimum, then defragment. I recommend using a 3rd party program such as Diskeeper, since windows defrag Isn't very good.
    If you can not free up enough space because all of your things are too important to delete, think about buying an external hard drive to back up too, or simply look for a bigger hard drive of the laptop and copy the old hard drives contents to the new one using something like norton ghost.
    Most likely you would need a laptop hdd to desktop hdd converter, which is like $5 or less, so you can copy the contents since laptops can only have one hard drive (usually). If you can't do this or don't want to try it, bring your laptop to a pc repair shop and they will transfer your data to a bigger hdd for you for a nominal fee.
    Remember, I do not guarantee this to fix your dvd problem, but it is a good idea to do it anyways to increase performance and reliability.
3 Related Answers
Kawika-56
David Lagesse
  • 233 Answers
SOURCE: CD / DVD player not listed as device on Windows Explorer
Go to your "Device Manager" (Right click on ‘My Computer', select 'Properties', click the 'Hardware' tab, click the 'Device Manager' button. Click the "DVD CD-ROM drives"). If there is some kind of a "Warning" icon superimposed on the 'DVD' icon there is your problem!
If no "Warning" icons then try...
Double click the device.
Click the "Properties" tab; look for any "Warning" icons
uninstall the DRIVERS for THAT DEVICE only. See instructions below.
Click on the faulty device and hit the remove button, follow the instructions given by the program.
Shutdown, restart, the device will automatically reinstall by the "Found New Hardware" program.
NEXT -- Your Hard-drive is OVER-FULL
You need to uninstall a lot of programs.
Select the ones you never use.
After uninstalling
Then do a search for 'all files and folders' - search for both whatever "Company Name" and then whatever "Program Names" associated with what you uninstall, with the options "Search system folders", "Search hidden files and folders" and "Search sub-folders" checked. Delete all of those found.
You should do this search and delete whenever you uninstall any programs. It will remove lots and lots of leftover junk files taking up room on your hard drive. It will also give you a "clean install" when you reinstall or install an updated program. Do this ESPECIALLY when updating to a NEW anti-virus programs and “Internet Security Suite” programs such as McAfee or Norton etc.
You will probably have a lot of left over Registry entries and errors leftover from this, try a registry repair program such as 'Registry Mechanic'.
Get rid of files you no longer need.
Or you can buy an external storage hard-drive or a larger hard-drive.
Then defrag.
Posted on Nov 01, 2007
Anonymous
  • 324 Answers
Try physically removing the player and fire up the laptop. Power down the laptop, replace the player and power back up. If that doesn't help, see if BIOS recognizes it.
If that doesn't work, get back to me.
Ron-
Posted on Nov 09, 2007
Anonymous
I also have the same problem. I've tried all the above plus some added info. The floppy still works when I swap it with the DVD. Occasionally it works for a short time right after a hard boot but soon after it appears to uninstall. I have searched the net for answers to this problem without success. I tried the registry correction without avail. There has been some online comments that the problem appeared after an auto update from uSoft. I believe the problem is software or firmware related.
Posted on Dec 28, 2007
I cant get a wireless connection on my IBM R40 using a Linksys G
I had the same problem with my R40 (2681) and a Linksys G router. The specs on IBM's/Lenovo's site indicate that the wireless card in the R40 only handles certain types of wireless encryption. The newer types (e.g. WPA) won't work on it and they are usually the standard on routers nowadays. My Linksys G router works fine with the R40 with WEP or with no encryption. Not ideal, but that's life with an old laptop.
Dec 14, 2009 | IBM ThinkPad T40 2373 Notebook
Installation instructions for dvd/cd combo for IBMLaptop.
If it is a direct replacement drive, exact size as old drive, then all you need to do is remove the old cd drive and slide the new drive into the slot until the back plug engages. Install new drivers as needed and any software that came with new drive. Hope this helps.
Jan 24, 2009 | IBM ThinkPad (22P9163OB) (22P9163-OB)...
Ibm thinkpad r40 laptop just installed new harddrive, powers up no operating system found..... reorder harddrive, still no change setup and booted from cd, no change when placing windows xp cd will...
The problem is that you need to boot up the laptop with the CD as the first boot device so you can then install Windows XP.
If you press F12 a boot up you will get a list of alternate boot devices oher than the hard disk as the first boot device, which was set up in the BIOS. Select the CD as the first boot device and when prompted press the space bar to start the CD.
Jan 07, 2009 | IBM ThinkPad R40 2722 Notebook
D drive lost
Hi and welcome to FixYa,
Initially, pls download this quick fix patch. This addresses problems such as what you are experiencing in both Vista and XP.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 18, 2008 | Lenovo Thinkpad T60 Notebook
IBM R40 hardware malfunction
press F1 on boot up and get into the bios, reset defaults and then chane the boot order to the CD/ROM, save changes, reboot and you should be able to install XP
hope this works
kind regards
Nov 18, 2008 | IBM ThinkPad R40 2897 Notebook
Problem with some keys of keyboard
1. Sourcing a keyboard is easy, check EBay. Fitting it is easy, two or three screws from underneath and a single connector takes care of that. I just did one, and the keyboard cost me 20 pounds.
2. If you don't use the CD / dvd drive, then consider purchasing / loaning an external cd / dvd drive, which you then connect via USB. You can then reload Windows from this new device, and it will serve any new computers you may have in the future. Expect to pay 20 to 30 pounds from any high-street retailer.
To boot from this device (which you would want to do in order to load Windows from it), you will need to access the BIOS, and change the 'boot order'. So you interrupt normal boot, by pressing F1 (could be different o your comp), and make the USB cd / dvd the first device in the boot list.
Good luck.
May 16, 2008 | IBM ThinkPad R40 2722 Notebook
Ibm thinkpad r40
I need the instruction on how to install a replacement DVD/CD player on my IBM R40 thinkpad Laptop.
Thanks,
Moses
Feb 22, 2008 | IBM ThinkPad (22P9163OB) (22P9163-OB)...
R40 DVD Read Problem
Unable to read a CD-R or other recordable disc. DVD recordable discs - If you have a DVD recordable disc and are unable to get it to read verify that the DVD drive is not a Gen 1 DVD drive and/or that it .
Computer DVD Support The DVD technology is very different from the technology used in standard CD-ROM drives. DVD uses shorter wavelength lasers to read smaller pits and lands.
Computer CD-ROM drive help and technical information. However, DVD-RAM discs cannot be read by standard DVD-ROM drives because of the differences in both reflectivity of the medium and the data format.
Read & follow instructions/Please dont for get to Vote/Thank You.
Dec 23, 2007 | IBM ThinkPad R40 2722 Notebook
Ron-
Nov 09, 2007 | Computers & Internet
Oct 31, 2007 | IBM ThinkPad R40 2722 Notebook
IBM ThinkPad R40 2897 Notebook Logo
Top IBM Computers & Internet Experts
Michael Thomas
Michael Thomas
Jax Planet
Jax Planet
efs_perpends
efs_perpends
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
