Quartet gbc 75X Shredder Logo
J
JOE Posted on Apr 02, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
On, Fwd, Rvs button has stopped working on my Shredmaster 75X. How do I fix this?
Big Steve
Level 3:
  • Quartet gbc Master 1,087 Answers
  • Posted on May 21, 2014
Big Steve
Quartet gbc Master
Level 3:
Answers
1087
Questions
0
Helped
244948
Points
2442
First check the power point is still working - plug in another appliance, like a table lamp. If OK check the fuse in the shredder cable plug.
The commonest reason for a shredder stopping is a paper jam, or running the shredder for too long. By 'too long', many shredders will cut-out after 5 minutes continuous working, and the sensor may take 15 minutes to cool down! Read the manual.
It maybe that the shredder cutters are jammed. Unplug from mains, and lift off top and place upside down. Use a small screwdriver and/or long nosed pliers to poke at any compressed paper wrapped around the blades - can take a while.
75X GBC SHREDMASTER DOES IT CUT CREDIT CARDS
If it is this 75X, yes ot does
Separate safety slot for CDs and credit cards with unique twin-bag design keeps plastic and paper shreds separate. Large capacity bin lets you shred longer between bag changes. Shredder Type: Confetti-Cut; Recommended Shredder Users: Up to 5; Specialty Shredding: CDs/DVDs; Credit Cards; Paper Clips; Staples; Motor HP : 0.333.
https://www.amazon.com/o/ASIN/B00000J4AJ/ref=nosim/cheapstrikeco-20/
On, Fwd, Rev button on my Shredmaster Model 75X stopped working. How do I fix this?
Check the mains supply is still on, and the fuse in the cable is ok.
Most problems are caused by james, and solved by removing the cover and unjamming the cutters. Can be tricky!
Can't connect to localnetwork
Select your network , enter your password --- then ok to connect - upon it failing to connect to local network -- do the following - press home button 5 times, fwd button 3 times , revs button 2 times - takes u to a sub menu - select update software --- after completed - follow steps on screen & connection should work -- if not then press home button 5 times , fwd button, play button, revs button , play button, fwd button -- sub menu opens select disable ping - then do setup - and connection should occur
1helpful
I have an issue with my FWD/DND function. Until yesterday, I was able to receive "in" calls. Apparently I accidentally hit the FWD/DND button! At first I wasn't getting ANY calls (never used...
I don't know about a "user guide" but the Operating Manual would work wonders. http://www.public.carl.airpost.net/Pana/TDA/200_TDA_OM_06-121.pdf
The FWD/DND button has 3 steps of keypress, Off, FWD, DND. The idea is you press it until it stops flashing or being lit and you have nothing set. If that doesn't work, try Call FWD/DND cancel, *7100 on the intercom.
Carl
Need a starter for 3 phase motor with only two buttons, one for farward & another for reverse.button should be bell switch type, when presssed and hold, motor should run and should stop when released.
You will need a fwd-rev starter (has two contactors) You can buy any brand. You should have three buttons fwd stop rev
You could wire it so the fwd latches until stop is pressed, and the rev button momentairly so it stops when finger is removed.If you buy a brand with a general purpose (NEMA 1 ) enclosure you could put buttons in the cover, some even have buttons made for their covers.
Aug 11, 2010 • Garden
2helpful
How to fix a stuck shredder
get a pair of needle nose pliers and pull the jammed paper out. (you may need to figure out how to pop off the top cover to get better access to the blades)
Please Help
We had the same problem at our office. Our machine is also about 1 year old. We checked the warranty and it is covered under a 3 year manufacturer warranty.
The repair person said that the whole motor gave out and they are replaceing it with a new one.
Get it fixed for free.....its still under warranty.....
Hope this helps.
Top Quartet gbc Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Quartet gbc Office Equipment and Supply Expert? Answer questions, earn points and help others
