Hi Steve,
The waste toner tank is the gray L-shaped container to the left of the cyan (blue) toner cartridge. Pull on the tab handle and either shake out the waste toner into a deep trash can (VERY messy) or outside into a trash can, then replace the old one if emptied or use a new one. Should be able to get it at a larger office supply store. Hope this helps.
SOURCE: getting error message on samsung clp 510 printer
yes refilling will solve the problem.but you have to change the green colour small chip on the side of the toner to make it work,as the new chip will be detected as new toner in the printer.
SOURCE: Install Cyan Toner Error
ensure that the one you install is the exact model name and number, if this is correct, try unistallling once again and check one more time,
you might want to get a new cyan toner if this still fails, i dont think there is a prob in your machine, cheers
SOURCE: Toner empty message
I would try to unplug the printer and leave off for a few minutes. and see if that resolves the problem.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_7148ad2a373711a3
SOURCE: I'm trying to install a new toner cartridge into
most toners have a wing or *** or? that contacts a sensor in some way when the lid closes to tell the machine a toner is present. ive had these pieces broken off on new toner or the toner sensor may be disloged from its seat. check around the perimiter of the lid to find the sensor then see if anything is present to trip the sensor. if its broken off stick a q-tip in the sensor that will get you printing til you can replace the part
SOURCE: I keep cleaning the toner/printer
How are you cleaning the tank? Just dumping the contents into a trashcan may not work. The printer uses a light sensor to detect whether the tank is full. When the light does not shine through the clear window of the tank, the printer thinks that the tank is full. Sometimes cleaning the window with a cotton swab will make it work, but it can be difficult since the location of the window with respect to the opening of the tank is not a straight shot.
Another way to clean it would be dump the waste toner into ther trashcan. Tap the tank a few time to get as much of the toner out. Then add some soap and water into the tank and seal the tank opening with the green lid. Then shake the soapy water in the tank for a about a minute. Then dump the soapy toner/water out. Rinse again with just water and and allow it to dry. You don't have to get the tank completely clean, just enough to stop the waste tank error message.
Hope this helps.
