Question about Toshiba E-Studio 356 Multifunction Copier
C440 error c440 toshiba studio e365
4 Related Answers
Anonymous
  • 3 Answers
SOURCE: toshiba e-studio 232 says c440 code
This problem is caused by the thermister in the fuser section. To reset shut macine off, then turn it on while holding down the 0 and the 8 key down for more than ten seconds then release. This is service program mode, now press 4 then 0 then 0 and then the start key, you will see a nuber in the screen, press 0 then start key this should reset that code if not the thermisters need to be replaced
Posted on Apr 11, 2010
mce_sys
Engr M A Al Mamun
  • 41 Answers
SOURCE: toshiba estudio 4511 error code C440
Press 0-8 then enter 400 and make it 0 then press print switch, if doesen't work u have to change thermostar, then if not working change heater, if not then IH board, and the last solution is to change the system board.
Posted on Jul 24, 2010
djuksoni
Branko Djurdjevic
  • 103 Answers
SOURCE: Error code c440. call for
Fuser unit error code, need to replace fuser unit
BR
Posted on Feb 12, 2011
Anonymous
  • 29 Answers
SOURCE: cada ves que predo mi
tienes un problema en el area del fusor, lo puedes resetear siguiendo estos pasos:
1.- prende la maquina presionando 0 y 8. espera unos 5 segundos hasta que la copiadora haga un sonido y prenda en test mode
2.- escribe la numeracion 400 y presiona start.
3.- te debe de aparecer un numero de error, para resetearlo solo escribe 0 y dale set o start.
4.- apaga y prende el equipo normalmente y has pruebas funcionales.
si tu equipo sigue marcandote problemas vas a necesitar reemplazo ya sea de las resistencias termicas y el sensor de temperatura, algun fusible o alguna tarjeta controladora de alto voltaje.
Suerte...
Posted on Mar 23, 2011
Error code C440
Toshiba eStudio 355/455 Full Service Manual - Tradebit.com
https://www.tradebit.com/.../155135538-toshiba-estudio-355-455-full-se...
Download Toshiba eStudio 355/455 Full Service Manual ... Configuring DepartmentCodes Configuring ... TSB-1013: C440 Error - Countermeasure .... DIG-ACC-145: MJ-1025 Bracket Change to Enable Installation on e-STUDIO205L/255/305
Aug 08, 2015 | Toshiba E-Studio 305 Digital Copier
Toshiba E-Studio 356 Copier error C440
can do [1] cancel 0+5 together touch and main switch on 400 touch print switch touch 0 touch inter-up touch and do off on [2] change thermostat [3]heater bod chang
Aug 17, 2014 | Toshiba E-Studio 356 Multifunction Copier
What is error c440 of toshiba photocopier
Toshiba e-studio Error code c440 is just problem with Fuser Unit after warm up time . 200L/ 202L/ 230/ 232/ 280/ 282/ 283/ 233
PROBLEM:
Fuser unit problem,
SOLUTION:
Try to reset it:
1. Hold down "0" and "8" keys while turn on the power.
2. Enter 400 press Start.
3. Enter 0 press Set or Enter.
Hope this helps
you can find more info at this link
Apr 28, 2014 | Toshiba E-studio 352 Digital...
Toshiba e-356 error C440
He did not find 400 benefits and pressure on the Toshiba 356se type
Feb 16, 2014 | Toshiba E-Studio 356 Multifunction Copier
C440 error
chik tha power suppl bord
Nov 15, 2013 | Toshiba E-Studio 456 Copier
E studio 456 c440 error code solution
Hi
C440 error on device problem toshiba e-studio 456 se
Please let me correct code.
400-08 code did not work on 456
Thanks
May 22, 2013 | Office Equipment & Supplies
TOSHIBA E-STUDIO 452 showing error code C440 problem solutions
How con i INCREASE , color of copy in toshiba 452
please sent to my add the GUIDE code toshiba 452
[email protected]
Aug 12, 2012 | Toshiba Estudio 200L Copier
TOSHIBA E STUDIO 280 CALL FOR SERVICE
First of all check what is sub code with this .if it is not showing code press clear & 8 key at same time .code will bi shown .if no code just reset pm cycle count.MIAN AKHLAQ
Dec 31, 2008 | Toshiba e-Studio 350 Copier
Toshiba E-Studio 356 Multifunction Copier Logo
93 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
Timothy Van Der...
Muntejaya Ginting
Muntejaya Ginting
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
