Question about Chevrolet 1996 Chevrolet S10/s15/sonoma Radio
P1103 code engine stumble when accelerated
Posted by Raymond Durden on
engr segun
    New Friend:
    Problem Solver:
  • 8 Answers
Have you changed the MAF sensor
Posted on Apr 02, 2014
Engine light on, flashing and hesitation when accelerating?
You will have to have your vehicle scanned to retrieve trouble codes. with the codes diagnostics of the problem can be more reliable. It could be something as simple as a vacuum line cracked or off. check links below for more info, press the helpful button.
Problem 4 Engine Hesitates Stumbles Lacks Normal Power
Fix Your Automotive Engine Hesitation Like Pro Pictures
Diagnose Engine Hesitates When Accelerating Auto Repair Help
Jan 27, 2016 | Cars & Trucks
Car stumbles up hills upon acceleration and always stumble at 43 mph. it has 120,00 miles
We need a little more to go on.
Any trouble codes stored? check engine light on etc.
Could be ignition or fuel related. A vacuum leak.
need more to be more specific.
Mar 02, 2015 | 1985 Chevrolet Corvette
P1103 CODE FOR 1998 IZUZU HOMBRE
P1103 Mass Air Flow Sensor In Range But Higher Than Expected. You can try to clean the MAF sensor elements with the proper spray cleaner (never tough them with your fingers), check for torn tubes to and from the MAF sensor to the throttle body, it must be sealed properly from MAF to throttle body. Disconnect the battery for 20 minutes and reconnect. If this doesn't take car of it you may need to replace the MAF sensor.
May 14, 2014 | Wings West Izuzu 94-98 Hombre Ext. Cab...
- stumbles when stopped and accelerating at low speeds
ENGINE HESITATES WHILE ACCELERATION
LOSS OF ACCELERATION
It can be fuel pressure issue or it's the problem with accelerator pedal or its clogged filters causing there.
There are many other possibilities. I suggest you to go through the list of help links mentioned below, these will help you to confirm where the actual fault lies: -------
Jerks and Hesitates During Acceleration?
http://technoanswers.blogspot.in/2012/07/2004-dodge-town-country-jerks-and.html
Loss of acceleration?
http://technoanswers.blogspot.in/2012/02/loss-of-acceleration.html
Headlights flickering and car hesitates to start?
http://howtobyme.blogspot.in/2012/02/headlights-flickering-and-car-hesitates.html
How exactly the Vehicles Accelerator Cable works?
http://repairhelpcenter.blogspot.com/2011/11/how-exactly-vehicles-accelerator-cable.html
How exactly Vehicles Accelerator Pump Diaphragm Works?
http://repairhelpcenter.blogspot.com/2011/11/how-exactly-vehicles-accelerator-pump.html
2000 Toyota Avalon: Engine Lean Codes and Knock Sound on Acceleration?
http://whatisbyme.blogspot.in/2012/05/2000-toyota-avalon-engine-lean-codes.html
2004 Toyota Avensis: Acceleration And Deceleration makes noise on Front End?
http://whatisbyme.blogspot.in/2012/05/2004-toyota-avensis-acceleration-and.html
Wheel hop under hard acceleration?
http://technoanswers.blogspot.in/2012/04/wheel-hop-under-hard-acceleration.html
2009 Chevy impala accelerator pedal sensor?
http://technoanswers.blogspot.in/2012/02/2009-chevy-impala-accelerator-pedal.html
Nissan Pathfinder stalls and bucks on Acceleration?
http://technoanswers.blogspot.in/2012/02/nissan-pathfinder-stalls-and-bucks-on.html
Acceleration lag problem?
http://repairhelpcenter.blogspot.com/2012/01/acceleration-lag-problem.html
These details will help.
Thanks.
Dec 07, 2012 | Cars & Trucks
Keep getting po102 if using a scanner to read codes but the engine light is not lit. does periodically have a stumble on acceleration. checked hoses, cleaned throttle body , replaced mass air sensor. runs...
if the problem for p0102 was repaired & the ck engine lamp is off then i would'nt be
concerned. the computor will erase code from its memory after it does'nt see the problem
any more.it will store in history codes for awhile
Jun 22, 2011 | 2003 Chevrolet Impala
1994 Silverado stumbles on acceleration when cold
Is the check engine light on? If it is, take the truck to an autoparts store and have them use a scan tool to retrieve the fault code(s) stored in the computer. I would suspect a faulty throttle position sensor or bad EGR valve, but the code(s) should narrow the problem down. Sure hope this helped.
Jul 20, 2009 | 1999 Chevrolet Silverado 1500
Stumbles and backfires on acceleration
Check the distributor shaft. They have a history of developing finite cracks that causes the condition your describing. Let me know if I can help you with any other info.
May 16, 2009 | 1993 GMC Jimmy
Chevrolet 1996 Chevrolet S10/s15/sonoma Radio Logo
119 people viewed this question
Top Chevrolet Audio Players & Recorders Experts
Marvin
Marvin
Lawrence Oravetz
Glenn Smart
Glenn Smart
Are you a Chevrolet Audio Player and Recorder Expert? Answer questions, earn points and help others
