Question about Faby Cab S.p.a Faby CAB Frozen Drink Machine 2 Bowl
My faby slush machine is freezing up
My machine is getting too cold and the product is getting too thick.
Posted by Gary Older on
jasbo
  • Faby Cab S.p.a Master
  • 2,239 Answers
Mix too lean. add a bit more base. also check the torque switch next to the stir motor. if it's stuck open, it won't stop freezing
Posted on Jan 03, 2015
What grade of oil for a 8.5 bourse snow blower
5w30 for cold weather. Anything thicker (higher numbers) will be too difficult to start on a cold morning. Oil will be too thick
Aug 17, 2014 | Yard Machines 26" 208cc Two Stage Snow...
How can i fix my manitowoc qm45a runs water but won't freeze the water?
The thickness sensor is shorting, making the machine continually harvest. Clean it and dry it. If it still happens, replace the sensor.
Aug 05, 2014 | Manitowoc Compact Undercounter Ice Machine...
Max harvest retrying
Likely cause,
1. Ice bridge thickness too small, not enough ice to open curtain.
Solution, Check and adjust if needed.
2.Ice bridge thickness too large, ice frozen to evaporator frame.
3. Purge valve dose not open, water melts ice bridge, not enough ice to open curtain.
Solution, Check purge valve.
4. Incomplete ice formation.
Solution, check water distribution for partially plugged holes.
5. Curtain out of position.
Solution, check curtain for swing restriction.
6. Curtain switch dose not open when curtain does.
Solution, Check switch with ohmmeter.
7. Machine in very cold ambient area.
Solution, Move machine to warmer location.
8. Hot gas valve dose not open.
Solution, Check hot gas valve, check controller using test mode.
9. Harvest assist probe out of position - ejector pin not retracted.
Solution, check harvest assist mechanism-spring should retract pin.
10. Damaged evaporator.
Solution, Check evaporator surface now would be a good time to make sure evaporator plate is not dirty this will cause ice to hang up on evaporator plate also check plate to make sure all cross points are not loose.
11. Fan motor stays on during harvest.
Solution, check controller using test mode.
Jul 18, 2013 | Scotsman HD22B-C0322MA-1B Hotel / Motel...
Worth fixing dryer that is getting oil spots on clothes model mah5500bwq
This machine has no oil in the tub assembly. Over a period of time and using cold water washes body oil, dirt and undissolved detergents and fabric softener will accumulate at the water line on the inner wall of the outer tub. After the gunk builds up thick enough parts of it will break loose at times when using hot water and then get on the clothes.
Nov 03, 2012 | Maytag Washing Machines
How do I sew over thick material?
There is a product called a jean-a-ma-jig which is just a piece to keep the needle level. A piece of cardboard 1/4" thick will do the same. It has to be behind the presser foot. Also, make sure that you have a 14 or 16 needle. In other words, treat it like it is denim.
Dec 09, 2010 | Sewing Machines
What is the required wall thickness required for the pressurized water tank using stainless sheet with a diameter of 36'' and a hieght of 80'' ? using a pressure supply of 40psi.
So are you going to build your own? Is it going to be for cold water only? Cheaper to buy a safe manufactured one. And a bladder tank is even better : Shell thickness: The minimum thickness
of a shell shall be determined using the
following equation:
Ts = PR/ES
E = Weld efficiency for longitudinal welds
(0.85).
NOTE: E = 1 if 100% of production
is tested at the maximum
working pressure.
S = Yield strength 20,000 psi
(140,000 KpA) or greater if certified
by the manufacturer.
See this link. http://www.watersystemscouncil.org/VAiWebDocs/standards_docs/ANSI_Final_0905.pdf
Jul 16, 2010 | American Standard Plumbing
Machine stops sewing when I hit a thickness
it may be that your motor belt needs tighening or the belt may be damaged - you can check belt and adjust tension yourself once side cover is removed.
if you are sewing thick seams and the needle is resting on the seam as you begin to sew you may have to help the machine to get started. if the fabric is not thick it must be belt tension.
scott.
Jun 17, 2009 | PfaFF Hobby 4260
My Whirlpool Calypso top loading washer (purchased in June of 2002) is starting to leave brown or dirt colored marks on clothing and sheets (I think they are permanent!) - I don't see any obvious place...
Run the washer empty with vinegar on the hottest, longest cycle. Usually this is caused from fabric softener and liquid detergent build up. Use powder detergent only and don't use cold water to wash in all the time. Only use cold water for your bright, finer cloths. Cold water use causes detergent build up.
Apr 05, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Scotsman ice machine problems.
Well it is making ice cubes alright just too thick right? I would give it a good cleaning with nickleguard and retry. If it is still doing the same thing I would replace the ice thickness switch.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 05, 2008 | Scotsman CSW45 15" Ice Maker with 26 lb....
Faby Cab S.p.a Faby CAB Frozen Drink Machine 2 Bowl Logo
1,250 people viewed this question
Top Faby Cab S.p.a Kitchen Appliances - Others Experts
Marvin
Marvin
john h
Tom Chichester
Are you a Faby Cab S.p.a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
