Car Audio & Video Logo
Question about Hifonics Car Audio & Video
Internal fuse My 1700 watt brutus amp lights up blue, but the protector light on the side is re and the green power light is not on. My bass knob light is also red instead which it is suppose to be green. What could be the problem if my amp is still light blue?
Posted by carl on
alero1
    New Friend:
    Problem Solver:
  • 11 Answers
Amps getting power that's good it seems as though either you have a cross in your bridge or you fried your amp
Posted on Apr 02, 2014
5 Related Answers
Anonymous
SOURCE: My Power Protector Light wont turn Green
switch off the amp then take off all the wires off including the speaker wire and then reconnect the wires on like before the problem is that the amp is on protection and if that dont work then get it repaired another thing is make sure ur amp fuses havent blown.
Posted on Mar 06, 2007
Anonymous
  • 631 Answers
SOURCE: no sound in my Hifonics Brutus BXi 1206D amp
Have you confirmed that you have a good signal feeding the amp?
Have you confirmed that the speakers are in good working order and don't have any breaks in the wiring?
Posted on Jan 02, 2008
Anonymous
SOURCE: power protector light on sony xplode 1000 watt amp
a green light is the power indicator, a red light is when the protector is in affect
Posted on Jun 01, 2008
Anonymous
  • 65 Answers
SOURCE: sony xplod 1000 watt amp not working
you need a amp kit your battery or alltinator isn't powerful enough to handle the wattage you need a juice can it gives yur battery more power
Posted on Jul 01, 2009
Anonymous
  • 18 Answers
SOURCE: Green light wont turn on, but the amp has some power because it is lite up blue.
I have the same problem in my car, and both the fuse in the amp and battery are good, is there another fuse I am not aware of that I should check?
Posted on Jul 29, 2009
I have a brand new Hifonics amp 1500 watt Brutus the only thing that powers up is the logo the power light and protection light stay off the amp brand new out the box what can be the problem
Some amps will not power up internally if u donot have remote wire. Also if u connect power then remote wire it will not power up until u reconnect in correct order. But if all that is ok. Than u have a bad amp
Amp keeps blowing internal fuses on a memphis 16-mcd1000
got pyle pta 3000 watts dj power amp when turn on my power light indcatior light dont work but it still runs
I got a sony xplod amp 1000 watt everything is connected good the ground wire is on a bare metal surface 12v wire good power fuse ALL wiring is as it should but there is no bass? the green light is on but...
Open your sub-woofer and check the continuity of your bass speaker. Chcek also the fuse of the sub-woofer amp...the fuse might be busted already.
1helpful
2answers
Protect Light problem
I'm having the same problemdid you ever figure out what it was ?
3helpful
3answers
Power protector light on sony xplode 1000 watt amp
Top Hifonics Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Jaime Hernandez
Marvin
Marvin
Are you a Hifonics Car Audio and Video Expert? Answer questions, earn points and help others
