Plastic cable for drain plug
SOURCE: sink drain slow
You can purchase a device from Home Depot that will clean out the drain. In the plumbing business, we call it a blow bag. But some call it drain dog and so on. It's a black rubber bag that fills with water and then when it reaches a certain pressure it blocks the drain but runs water through it until the clog is dislodged. You attach it to a water hose and push it into the drain as far as you can get it. Run it for 15 to 20 min. and then pull it back out. There are several sizes to accomadate the pipe size. You sill need the one that does pipes up to 2 inches. You will have to remove your drain assymbly under the sink to do this. While you have the drain assymbly off, you can make sure it is clean as well. This will clean out the garbage that collects in the pipe. Hope this helps.
SOURCE: kitchen sink drain loose
You can probably tighten it from the bottom. But first, get a little plumber putty from the hardware store and put it around the seal from the topside of the sink. As you tighten it down, it will squeeze out a bit, but that is okay. Good luck!
SOURCE: kitchen sink drain is leaking
Yes all can be replaced. They sell complete replacments at Orchards, Home Depot or Lowes. Just make sure you are getting the right parts.
SOURCE: Slow tub drain
I am not completly sure about the kohler,but i think that you have a toe tap drajn.You should be able to un-screw it counter clockwise.IF you can get it un-screwed look at the bottom of the toe tap.There will be a screw or a plastic nut.I beleave that you loosen it to raise the drain I hope my information is correct,I will certanly do some research on your drain.
SOURCE: Direct push-type Kohler bath drain won't drain.
Spring loaded chrome stopper will not stay down to fill tub with water.
