Sewing Machines Logo
Question about PfaFF Quilt & Craft Pro 7530
Any one know?
Nothing on screen. Took out old battery and cleaned still no sew.
My Babylock Esante ESE's screen lights up but that's it. Why does nothing else happen?
the computer may have a problem, it would be a good idea to have it checked
2answers
Won't get off of brightness screen
Needs a circuit board or a new screen, you can't do it yourself.
2helpful
4answers
Singer curvy beeps 4 times and stops sewing
when you thread the machine make sure to use every thread guide
check to see if the bobbin is in correctly
try changing the needle--normally flat side goes to the back
the needle that your sewing with is it the right one for the thread & fabric
clean under the needle plate & bobbin area for lint or loose threads
My old reliable sewing machine will not stitch. I took it apart, cleaned & oiled everywhere, inserted a new needle & still no stitching. I checked everything I know how to check & don't know...
It could be a timing problem - the bobbin thread must be carried through the needle thread at a precise point in the needle's up-and-down cycle.
Look for your manual and see if it tells you how to adjust the timing.
If you don't have a manual, I found on for my 1960's machine on ebay for $8.
If neither of the above work, take it to the repair shop for adjustment.
2answers
Machine won't sew at all
RE: Euro-Pro 9000 Mechanical Sewing Machine "Won't Sew"
I am wondering if you tried unplugging it for at least 1 minute to let it reset the onboard computer (sometimes they need to be unplugged overnight).
Try the following links....
FAQ @ http://www.euro-pro.com/europro/faqdetail.aspx?modelno=9000
Manual @ http://www.euro-pro.com/europro/manuals/9000.pdf
Customer Service @ http://www.euro-pro.com/europro/feedback.aspx
Let me know if I can assist further!
jackiaria
I need a new Motherboard for my MC4000. Where can I find one?
Try here, https://www.sewingpartsonline.com/janome-mc4000-sewing-machine-parts.aspx or try Janome them self .
3helpful
3answers
Feed Dog problem
Here are some common reasons that the fabric won't feed:
1. Stitch length is set to zero, or machine is in button hole setting
2. Feed dogs are dropped (free motion setting)
3. Broken gears (typically in old singers)
4. Presser bar not coming down - may be bound up.
5. Lots of lint under the needle plate (in between the feed dogs) preventing feed dogs from raising.
Hope this helps.
Puckered seams :-(
Try using a walking foot. It could be it's not the bobbin but the way the two layers are feeding together. Or, change feet. Or, try a new needle. Rethread the top needle, too--sometimes this alone fixes the problem.
Top PfaFF Sewing Machines Experts
Marvin
Marvin
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
