Need to replace carburator on honda 160cc engine with ARCS optionAlready have new part
Remove air filter cover. Remove air filter. Remove the 3 10mm screws mounting the air filter housing assembly and carb to motor. You will need new gaskets to install the new carb. Gaskets: 16221-883-800 2ea., 16212-ZL8-000, 16228-ZL8-000, and the gasket for the back of the air cleaner mount 17228-ZMO-000. You can buy the carb for these on line for about $14, 16100-Z0L-023. Most take a NGK PLUG BPR6ES.
SOURCE: i need to change the blade belt on my troy bilt 33 inch walk behind mower
look up on the internet the make and model of your mower and look under diagrams
SOURCE: Change Oil
All lawn mower engines have a drain plug for draining the oil. Look for a square nut on the side of the engine
SOURCE: MTD Yard Machines 22'' mower, pull cord won't extend
From what you describe it sounds like the line may be tangled, remove the rewind housing in order to inspect the line up close.
SOURCE: lawn mower husqvarna problem
I have an XT721F self-propelled, auto choke Husqvarna mower. The first time I used it this season it ran for a short time and then just quit on me. I have since emptied out all of the gas and have replaced it with high octane 91, and have also added Seafoam to clean out any other issues. I mowed two weeks ago with no problems and went to mow again today and only made it through 2/3 of my back yard and the mower stalled out on me again. What's going on?
