Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
Self-cleaning oven instructions for Kenmore oven
Self-cleaning instructions for Kenmore electric oven.
5 Related Answers
Robert Hirst
  • 833 Answers
SOURCE: i have alot of smoke when i use the self cleaning feature
Self cleaning works by 'burning' all of the material it is cleaning.  If you have excessive grease other material in the oven, it will cause the smoking.  Either do the cycle more frequently or remove as much of the goo as possible with a cloth before beginning.  If you have a ventilator to the outside, turn it on and close the door to the kitchen to contain the odor.
Posted on Nov 21, 2008
Anonymous
SOURCE: self cleaning oven directions
Press the self-clean button.  The panel becomes blank(---), then press the up arrow( ^ ).  The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning.  Good luck, ya'll!
Posted on Dec 09, 2008
Anonymous
  • 21 Answers
SOURCE: how does self-cleaning work on kenmore?
there is a timer and a locking relay when you shut the door and put it on self-clean then shut the door and latch it the relay kicks in and locks the door and turnsthe oven on max for a few hours the food resadue turns to powder that can be wiped off or vacumed out
Posted on Mar 11, 2009
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: trying to self clean my kenmore electric oven get
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 25, 2010
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Ultral Bake Self Cleaning Super Capacity electric oven
F2-E1 - Touch Pad (Keypad) Cable Unplugged -
Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
It appears your timer/clock has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Posted on Oct 01, 2010
Self cleaning oven f2
How do I clean a self cleaning oven.
Dec 09, 2013 | Kenmore 40494 / 40495 / 40499 Electric...
How do I clean Kenmore electric range model; 36393091300 .No manual for this self cleaning range.
Hi,Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Aug 24, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
Where can i get cleaning instructions for a Kenmore model 4652591 self cleaning oven?
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
heatman101
Mar 23, 2011 | Kenmore Ovens
My kenmore electric oven was put on to self clean and then immediately turned off but the oven door has remained locked. How do I unlock it?
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Dec 14, 2010 | Kenmore 49222 Electric Single Oven
When self-cleaning my oven do I turn up the temp to 400.
No, the self-cleaning cycle is automatic, and will raise the heat in the oven to a very high temp (500°F-600°F) then cool the oven.
Here is your manual, see page 17 for cleaning instructions.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0309524.pdf
Feb 06, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Self Cleaning Cycle for Oven
I lost the instruction manual for my Whirlpool 30" Electric Built-In Double Oven and want to clean it. Can I get instructions for how to set the cycle for self-cleaning, etc.?
May 10, 2008 | Whirlpool GBD307PDS Electric Double Oven
Self cleaning oven directions
Oct 24, 2006 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
19 people viewed this question
Top Kenmore Ovens Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
