There is a black goo on the right end of long horizontal rod visible under left ink catridge when front cover is open. rapid loud popping sound occurs before printing and also when front cover is openned or closed after cartridges reposition themselves. what is happenning and what can be done to stop it?
The popping noise is coming from the carriage belt jumping on the drive motor cog. It indicates that the cartridge carriage is jamming while the motor keeps spinning. It may be due to a wedge of paper at either end of the carriage bar (horizontal rod) or it may be due to a failing main board circuit.
SOURCE: HP1060 won't print
Have you looked at the front cover to see if the tab there is broken? (this will tell the PC that the front cover is still open) So you'll want to go around the edges of the printer cover to see if there's anything broken and a small hole in which the tab would insert into. If it is the case, and you don't want to spend money on fixing it, then do what I do...Rig up a paper clip and electrical tape to work as the tab, making the printer think that the front cover is always closed.
SOURCE: HP 7660 "Print Cartridge Cradle is Stuck" Message
I was having same problem but it was a paper jam all the time and then it started to state Cairrage Jam. And what was happening was the unit the cartridges sit in was not going all the way to the right. A little nudge and you could feel it move. Closed lid and sometimes it would print but eventually it would fail. Just replaced but I suspect if you can get to the cairrage you could clean/repair whatever was keeping it from going all the way to the right.
Hope that helps!
SOURCE: Black cartridge problem
Try the steps mentioned in the link bellow:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01091133&cc=us&lc=en&dlc=en&product=1141647
If it still does the same then the printer is not detecting the ink catridge, the printer might have to be replaced.
Good Luck
SOURCE: 932C Constant blinking ink light
problem here is the orange light blinking- has ink in the cartridge- stopped printing in the middle of the page
SOURCE: hp psc 750 won't print with new color ink cartridge
To solve the
printing problem..
# Hold the cartridge upside down, with the
bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the
cartridge on the bottom (where the ink comes out). Wipe the printhead
horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure
the ink is flowing.
# Next, look inside the printer and locate the
carrier that holds ink cartridges. Caution: Make sure the cartridges are not
installed at this point.
1. Look for a shiny piece of metal underneath the
contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and
wipe along the bottom of the shiny metal piece. Note: You may need more than
one swab.
# Reinstall the cartridges, making sure you snap
them correctly into the printer.
Hope this help. Please
Rate My Response! Thanks!
