Question about QuarkCopyDesk SE (115987) for PC
Internet run suddenly slow
Suddenly my internet run slowly.anything i can do to repair it?
Posted by baf23 on
Anonymous
  • 108 Answers
Just try deleting the cookies, cache and history from the browser settings to resolve the issue
Posted on Jul 01, 2008
neeshaw
    Novelist:
    Scholar:
  • 151 Answers
The best spyware remover for your needs depends on your PC, your level of expertise and the particular problem that you're having. For some advice on how to get the best from spyware killers , read on...
Spyware is a menace that, thankfully, most people using the internet are aware of now. Unfortunately, detecting spyware and removing it isn't always a straightforward process.
Posted on Dec 27, 2011
Anonymous
  • 63 Answers
Optimize your internet explorer and delete temp files and prefetch files scan your computer with updated superantispyware
Posted on Apr 20, 2009
David Lagesse
    Novelist:
  • 233 Answers
Could be from LOTS of reasons.
…Try the simple things first.
Have you done a "Defrag" lately?
Keep running it again and again untill it finishes in less than two minutes.
Spyware and Viruses can also a big slowdown.
You may have some spyware installed on your computer. If you have an anti-spyware program installed make sure it is NOT listed on 'The Spyware Warrior List of ‘Rogue/Suspect Anti-Spyware Products & Web Sites’
http://www.spywarewarrior.com/rogue_anti-spyware.htm
Those are "anti-spyware programs" that install their OWN spyware, while 'supposedly' removing everything else.
Use instead "Ad-Aware 2007", "Spybot - Search & Destroy", "SpywareBlaster", "Webroot SpySweeper" are four good ones out of many. Beware of imitations and name similarities. Install and update then run them weekly, after doing the latest updates.
Lastly, to stay OFF of Weird and Strange websites!  ;>)
Install McAfee SiteAdvisor.
Posted on Oct 31, 2007
Why is it running slower, locking up, and blacking out?
Sounds like a hardware problem. I suggest you contact the seller and try to get a replacement or repair under warranty.
Jun 22, 2015 | Tablets & eReaders
My Bosch jigsaw suddenly seems to run too slowly. It just doesn't cut as agressively as when new, and seems to turn less rpm. what's going on with it?
This may seem dumb but did you accidentely turn the variable speed dial on the trigger down? Not sure which model you have but that is the most common problem that comes into my shop with certain models.
Dec 17, 2012 | Bosch Saws
My internet suddenly quit working
sounds like a virus either way a reinstall will sort it back up any documents and pics first
Feb 11, 2012 | Toshiba Satellite L355-S7902 Notebook
Fan running slowly
It seems that the motor armature is burn or about to burn .
If you can fix it by yourself , then dissemble the unit, remove the motor. Loosen the bolts running from end to end of the motor and with emery cloth, clean the small metal plates on the end of the armature. They should be bright copper color. If the armature is burnt, they will be dull brown. The other thing is to replace the brushes in the motor . or call for repairing if you are not sure that you can do it by yourself .
PLEASE DON'T FORGET TO RATE !
Apr 21, 2010 | Hunter 23918 Classic Original Iron Fan
Model # - ET18HK - Refrigerator not cooling
Sounds like you have a leak in the refrigeration circuit somewhere. The refrigerant has leaked out of the system. It often will leak very slowly and you will not hear see of notice anything till the unit stops working.
To find the leak and repair the unit will probably cost more than buying a new one. These leaks are often very hard to find and many are not repairable anyway.
Nov 17, 2009 | Refrigerators
My XPS M140 is slow. It pauses for no reason
If the system is pausing for 10-30 seconds , there could be some bad sectors on the harddrive or , there are some unwanted programs running in the background
To check if your hdd is working fine
1. restart your computer
2. And press the F12 key slowly 5 times
3. Run onboard diagnostics on the hdd.
Thanks for using Fixya
Proton
Oct 18, 2009 | Dell Inspiron XPS M140 Notebook
Hi..I've been using CHrome for about a month. Suddenly, it now comes up very slowly, and then runs for about 3 minutes before saying 'Whoa, Chrome has crashed' Happens repeatedly. Whats Up? Thanks
try doing disk clean up and removing history saves pages and cookies scan your computer for viruses or bugs. Download a software ccleaner it removes all the unwanted files.u can also try reinstalling it.hope this works
Sep 26, 2009 | Google Computers & Internet
GAMES BECOMES RUNNING VERY SLOWLY
mmm do you have an antivirus running in the background? that would explain a lot, when it starts scanning it slows down your computer, see if you can disable it before starting any game
alex
Mar 25, 2009 | Computers & Internet
Laptop suddenly shutsdown at startup
First disconnect anything connected to the laptop not necessary for booting.
Next, when you boot start slowly tapping F8 function key after the BIOS loads, but before you see anything that says Windows.
A menu should pop up. Select Last known good configuration that worked from the menu.
If it still reboots, use F8 to get to the startup menu and select Safe mode.
If you can get to the desktop now in Safe mode, try running a System Restore back to before the problem occurred.
Go to Start > Programs > Accessories > System Tools and select System Restore.
Follow the prompts and select a bold date before the problem began. After the reboot the problem may be resolved, but you may have to re-install any recently added software.
If still no go, boot to the Windows CD and choose to run a repair.
Let me know if you need more help.
Honest1abe
Dec 30, 2008 | Computers & Internet
QuarkCopyDesk SE (115987) for PC Logo
632 people viewed this question
Top Quark Computers & Internet Experts
Ekse
 Grubhead
Grubhead
JonSnell Electronic
JonSnell Electronic
Are you a Quark Computer and Internet Expert? Answer questions, earn points and help others
