Question about Toshiba MK8025GAS 80 GB Hard Drive
Driver problem my laptop can't recognize the external hard drive toshiba mk8025gas 80gb. and i have try to reinstall again my window but still can't detect my hard drive. so any one can give me a driver for my hard drive please. there is important file inside the hard drive so please send me email or post in this web site where i can download the drive for my hard disk.thanks
Posted by vicient on
  • 1 more comment
  • wameed algadree Nov 02, 2007
    mk8025gas 80 gb hard drive
  • Anonymous Jan 07, 2008
    driver
  • awghaffar Apr 24, 2008
    My External Harddisk MK8025GAS 80 GB stopped working suddenly. It is not appearing as a Drive. But it shows as USB Mass storgae. It seems it is continously trying to read from the harddisk.
    Please Help.
Anonymous
    Novelist:
    Champion:
  • 244 Answers
Hi Vicient,
I have the following questions to evaluate the problem.
1) What's the port your harddrive supported? Is it standart IDE cable or SATA.
I have a hardrive utility software that can detect and access any type of harddrive but you need install it at running windows.
Please email [email protected] and dont forget to used the subject "Driver Problem" if sound interesting for you.
Sincerely,
Philip
Posted on Oct 31, 2007
Toshiba sr3 laptop wont start
Access internet, download Symantec Power Eraser. Run program.
Problem is initiated before hard drive is recognized. Program is FREE!
Feb 26, 2014 | Toshiba SATELLITE PRO M70-SR3 LAPTOP LCD...
My 80GB drive is not recognized anymore by any laptop, the blue and red lights are on and the drive turns, but nothing is seen in Explorer. It worked fine for 2 years. What can I do? I have 60GB of...
just in case
:click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
if your computer came with a motherboard disk the drivers could be on it
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
hope this helps
Jul 05, 2011 | SimpleTech Pininfarina 80GB External USB...
MY COMPUTER WON'T RECOGNIZE MY EXTERNAL HARD
hope this helps
Jul 03, 2011 | Toshiba Computers & Internet
Drive failed in laptop said no drive detected. placed drive into usb drive enclosure and it still doesnt detect it. help!
The hard drive is beyond repair.
To get your laptop working again, replace the hard drive with a new one, install Windows on the new hard drive, plus the laptop's device drivers and install your programs.
Feb 09, 2011 | Toshiba MK8025GAS 80 GB Hard Drive
Problem with Toshiba MK8025GAS hard disk
check the connection of the hard disk and make sure the cable is properly connected. also chek the setting on the CMOS. it should be recognised at CMOS level, make sure it is set on auto
Aug 21, 2009 | Computers & Internet
Laptop Won't Recognize External HD
You can try opening the device manager in Window XP and uninstall the external hard disk (make sure you show unplugged devices).
Then replug the drive again, and it should reinstall the drivers.
Jules
Feb 22, 2009 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
My laptop currently has a Toshiba MK8025gas hard drive, but it has been crash dumping randomly and I want to change hard drives. I also want to change to a 160GB hard drive. Is the Toshiba MK1652GSX...
The main factors in upgrading your drive are interface type and physical size, specifically the thickness of the drive. I haven't had any issues come up from substituting a drive of a different RPM yet. BTW I have a drive that's the same model as yours, it came from a computer that acted up like you're describing, the owner didn't worry about it, and one day it decided it wasn't going to wake up...you shouldn't have any trouble going from an 80gb to a 160gb drive.I believe your drive is an IDE interface, So just make sure you don't order a SATA, toshiba has comparable drives in either interface, I'd look for a good warranty period if the prices are about equal on the drives you're considering
Dec 03, 2008 | Toshiba MK8025GAS 80 GB Hard Drive
hi rezwann,try using different jumper setting on ur hardisk it might work.
raj
May 11, 2008 | Toshiba MK8025GAS 80 GB Hard Drive
Toshiba MK8025GAS 80 GB Hard Drive Logo
618 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
