Question about HP Photosmart 3310 Printer
HP 3310 All In One Error
My HP 3310 is coming up with the following error:
Ink system has failed, unable to copy, receive faxes or print. Refer to printer documentations.
Error: 0xc05d1281.
Can you pls help with what I need to do. I have tried rebooting..
Thanks,
Jenae
Posted by Jenae on
  • 1 more comment
  • Anonymous Nov 09, 2007
    Error: 0xc05d1281.
    Can you pls help with what I need to do. I have tried 50 times wont work!
  • Anonymous Dec 18, 2007
    everything
  • Anonymous Mar 19, 2014
    The balck ink does not print. But can't get any indication if the printhead can be replaced or taken out to clean?
Sandy Chamberlain
    Scholar:
  • 132 Answers
Try to reset the system by holding down the OK, Cancel, Black, and Color buttons at the same time and turn the 3310 off. Keep holding the buttons down until the printer shuts off and then turns itself back on. You will have to turn the printer off twice and then it will recalibrate. Make sure you have new cartridges in the printer so that it can reset.
Posted on Nov 01, 2007
  • santianito Oct 06, 2010
    probe todas las soluciones y no me lo resolvian,,, ya la hiba a desarmar... hasta que encontre esta
    muchas gracias... si funciona solo que uno tiene que apagarla porque no se apaga sola
    problema resuelto mil gracias
Thomas Christopher
    Genius:
  • 1,601 Answers
Issue An 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved. If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Anonymous
  • 14 Answers
Probably the plastic gear falling off its axel problem - I wonder why HP does not admit this inherent design problem and publish the solution - they really want everyone to dump their fairly new printer and buy a new one. It is really no big deal to fix for someone with some DIY skills. Refer to http://www.fixya.com/support/t439120-ink_system_failure_error_message
Posted on Oct 07, 2008
Anonymous
  • 4 Answers
Amigo, só para ajudar a divulgar aos usuários de Bulk. Se o código de erro 0xc18xxxxx ou 0xc19xxxxx do sistema de tinta da impressora HP Photosmart C6180 for exibido no painel dianteiro, faça o resete da seguinte forma:
1- aperte a tecla com sinal # (jogo da velha) e o número 9. Segure as 2 (# + 9) apertadas ao mesmo tempo.
2- desplugue a impressora da energia,
3- ligue (com as teclas ainda apertadas) e espere uns 15 segundos até a impressora desligar.
4- Aí é tudo normal, liga novamente ela pede as configurações iniciais, configuração da linguagem, faz a limpeza e OK!
A tinta preta original da impressora C6180 é pigmentada e as demais corantes. Contudo para o bulk-ink é melhor utilizar só tintas corantes que possuem melhor fluidez, evitando entupimentos e problemas. RESOLVI O PROBLEMA DO MEU BULK-INK SUBSTITUINDO A TINTA PIGMENTADA - QUE VEIO COM O BULK - POR TINTA TIPO CORANTE.
Posted on Feb 01, 2009
Anonymous
I had the same problem. The printer made a clicking sounds during maintenance cycle and gave a ink failure error. Look inside, on the left, in the gears there was a small piece of paper jammed. I removed it and the printer works.
Posted on Dec 29, 2007
  • siskin68 Sep 08, 2011
    The noise may be also generated by a gear which has fallen off the shaft. The mount then grinds at the gear of the printhead.
    If that happens, open the left cover of the printer, find the gear in the unit and bring it back into the shaft. Just clip.
I have an HP photosmart 3310 printer with an error message: INK SYSTEM HAS FAILED. UNABLE TO COPY, RECEIVE FAXES, OR PRINT. REFER TO PRINTER DOCUMENTATION. ERROR: 0xc18a0106 This comes on whenever I...
Why dont you try uninstalling this form your PC/laptop and reinstalling it again.
This should help restart the printer again.
Good luck and thanks for using Fixya
G.
Jun 14, 2011 | HP Office Equipment & Supplies
Ink system failure
I have a message on my printer
Ink System Failure
ink system has failed -unable to copy, receive faxes,or print.
error Oxc19a0107
Feb 10, 2011 | HP Photosmart 3310 Printer
I have a message on my printer Ink System Failure ink system has failed -unable to copy, receive faxes,or print. Refer to printer documentation error Oxc19a0002
Hi
Please do this and let me know
Unplug the printer, then pressing the help and ok buttons simultaneously plug it back in.
Let me know or Call +877 889 6859
Jan 06, 2011 | HP Photosmart 3310 Printer
I am getting an error message on my HP Photosmart 3310 as per below: INK SYSTEM FAILURE Ink system has failed. Unable to copy, receive faxes or print. Refer to printer documentation. error: 0xc19a0013...
Hi
There there to much to tell you what to do but I found a link for you to see it will tell you what to do just click on the link it will take you there.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458034&lc=en&dlc=he&cc=il&lang=he&rule=6783&product=3655608
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Nov 24, 2009 | HP Photosmart 3310 Printer
normally in this scenario the whole printer needs to be replaced..
Oct 22, 2009 | HP Photosmart 3310 Printer
Hp 3310 error 0xc18a0201
if you are a tech and have opened one of these before, clean the service station on the right side, oil the carrage rod. time about 1.0 to 1.5 hours. most of the time this is the problem on inkjets.
Feb 21, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Photosmart hp 3310xi - ink failure???
Perform the steps given in the below webpage and if the issue persists then contact HP.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00551397&cc=in&lc=en&dlc=en&product=439491#top
Jun 05, 2008 | HP Photosmart 3310 Printer
Error HP Photosmart 3310. No strart print, no scanning...
I have a Photosmart C6180 all in one and get an error message 0xc18a0101 Ink System has failed. Unable to copy, receive faxes or print. Refer to printer documentation. Error: 0xc18a101.
I put new cartridges in and tried to recalibrate as mentioned by someone on the board. Can anyone help, please?
Nov 16, 2007 | HP Photosmart 3310 Printer
HP Photosmart 3310 Printer Logo
5,592 people viewed this question
Ekse
Thomas F. Schneider
