Question about HP C4170-90959 Service Manual -15754
MINOLTA MD-1 MOTOR DRIVE MANUAL
I AM NOT ABLE TO FIND A FREE DOWNLOAD FOR MINOLTA MD-1 MOTOR DRIVE MANUAL.  I NEED HELP TO FIND ONE TO MAKE COPY.
THANK YOU,
ADRIENNE
[email protected]
Posted by SISU on
Anonymous
    Sergeant:
  • 274 Answers
Join
http://tech.groups.yahoo.com/group/ManualMinolta/
Look under "files".  I found it easily with no problem.  pdf file 828K but I can't upload to you.
Posted on Oct 31, 2007
Can copy from analog sources, but can't copy from digital source, eventhough the signal is monitored. The display says "can't copy".
Media
The unit requires Digital Audio CD-R or CD-RW media for
recording. Computer CD-R or CD-RW discs do not work with
this unit.
Serial Copy Management System
This unit is in compliance with the Serial Copy Management
System standard. This standard has been established to
restrict digital-to-digital copying to only the first generation.
The basic rules governing this system are as follows:
Rule 1
A digital recording is possible from a digital source such as a
CD, DAT or MD onto a recordable CD-R, CD-RW, MD or DAT
through a digital input connection. However, further digital
to- digital recording is prohibited for the second and later
generations.
Rule 2
When an analog source such as an analog disc or FM
broadcast is digitally recorded by using a CD-R, CD-RW, MD
or DAT, this recorded source can be digitally recorded on
another CD-R, CD-RW, MD or DAT. However, further digital
copying is prohibited.
Download the manual "cd-rw880_ef_manual.pdf" on the page linked below:
Download free pdf for Teac CD RW880 CD Player manual
Aug 22, 2013 | Teac CD-RW880 CD Recorder
I NEED A MANUAL FOR C 352 KONICA MINOLTA. WHERE CAN I DOWNLOAD IT
C352 KONICA MINOLTA Manuals
From the above link from Konica Minolta Official Support, 14 Manuals are available for Free download.
Please visit the above link and download the Quick Guide, Manual for Fax, Scan etc, according to your need.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 20, 2011 | Office Equipment & Supplies
1) Minolta XG1 35mm Film Camera 2)Minolta X300 35mm Film Camera Which batteries can I use for the cameras listed above?
XG1:
Two 1.55v silver-oxide (SR44 or equivalent), or two 1.5v alkaline-manganese (LR44 or equivalent).
You can download a copy of the manual at
http://butkus.org/chinon/minolta/minolta_xg-1/minolta_xg-1.htm
X-300:
Two 1.55v silver-oxide (SR44 or equivalent), or two 1.5v alkaline-manganese (LR44 or equivalent), or one 3v lithium (CR-1/3N).
http://butkus.org/chinon/minolta/minolta_x-300/minolta_x-300.htm
Feb 17, 2011 | Konica Minolta X300 35mm Film Camera
Am diabetic and have been given an old machine but no manual. need help to get one and ideas for diabetic friendly ice cream. many thanks. Adrienne
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Dec 24, 2010 | Microwave Ovens
Can I use MD lenses on my Minolta 5D or do I need an adaptor
The two lens mount systems are incompatible.
You can find adapters on ebay (listed as MD to MA or MD to Dynax) but they come in two varieties:-
The first is a straight converter, it allows the MD lens to attach to your camera, but as the lens is further away from the sensor/film plane than it was designed for you lose infinity focussing so the lens is only good for close-ups.
The second type is more expensive as it incorporates corrective optics to compensate and allow infinity focussing. But by introducing additional (and often suspect quality) optical elements you inevitably have a trade-off in image quality and may experience greater lens flare and chromatic aberrations.
Either way, an adapter leaves the MD lens completely unable to communicate any information to the camera body, and the body is unable to automatically stop the lens aperture down when taking photos. In practice, this means that you must use the camera in fully manual mode, manually focus at wide open aperture and then turn the aperture ring down to whatever you wish to use to correctly meter the light level in order to set the correct shutter speed.
All in all, it's a complete waste of time in my opinion and it would be simpler and far cheaper to obtain a suitable Minolta MD mount body to use with those lenses alone. They go for free/peanuts now, like many 35mm SLR bodies and you can try your local FreeCycle/Freegle groups before shelling out anything. Rare/collectable models aside, no MD mount body should go for more than £10-£20 unless it's guaranteed to have been freshly serviced with new batteries.
As you may be aware, newer Sony lenses will fit your 5D as they use the same mount, but they aren't anywhere near as cheap nor plentiful as MD lenses.
Hope this helps, all that I ask in return is for you to take a moment to rate my answer.
Feb 12, 2010 | Minolta Cameras
Minolta 430 SI RZ manual
Hi
You can download the manual for your Minolta 430 SI RZ from this link--
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 06, 2009 | Minolta Maxxum 7000 35mm SLR Camera
Manual microwave oven model for ER-761 MD
For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit here.
Some L.G. / Goldstar owner's manuals can be downloaded here.
Nov 19, 2008 | Goldstar Microwave Ovens
Mounting a teleconverter on a minolta camera
AS you have found out, the Maxxum AF mount and the MD mounts are much different. They do make tele-converters that allow the use of MD (non-AF) lenses on a Maxxum series camera. You would still need another adapter to make the MD Tamron converter work,
Jan 06, 2008 | Cameras
594 people viewed this question
Ekse
Thomas F. Schneider
