2006 Hyundai Atos 1.1 Logo
Michelle Goosen Posted on Apr 01, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Central locking problem
Hi, my manual central locking for my car does not want to unlock at all front the driver door. If I go to the passenger side of the car to unlock manually, it unlocks the front passengers door. please help, is it the door lock or is it my central locking?
Abdul Rasheed
Level 3:
Master:
  • Master 567 Answers
  • Posted on Jun 13, 2014
Abdul Rasheed
Master
Level 3:
Master:
Answers
567
Questions
0
Helped
181855
Points
1403
Change/repair the central locking motor inside the door.
5 Related Answers
Anonymous
  • 15935 Answers
  • Posted on Jan 22, 2009
SOURCE: central locking
Resolving this problem will require removing the door panel in question, and checking for voltage at the solenoid when the unlock button is pressed.
If there is 12V at the positive wire to the solenoid, but the door does not attempt to unlock, you must replace the solenoid.
Doors are not fused individually, so the fact the other doors are operating properly rules out fuses.
Remove the door panel, and check for voltage - if there is no voltage, the wiring is suspect. This would require more in-depth troubleshooting - checking wires for continuity to ground, and overall continuity.
Start with the door. Re-post your findings and I can help you additionally.
Thanks for using FixYa - Your FiXyA rating is appreciated!!
Anonymous
  • Posted on Feb 19, 2009
I have same problem
Found parts of a corroded spring in door mechanism
New spring solved the problem
Anonymous
  • 26 Answers
  • Posted on Apr 26, 2009
SOURCE: passenger rear door only locks and unlocks manually
the door lock actuators failing are a very common problem on the NF sonatas.
they are covered under 5/60
alicantecoli
Colin Stickland
  • 22516 Answers
  • Posted on Jun 21, 2009
SOURCE: Hyundai Excel 1997 driver's door lock won't unlock
the little metal rod that goes from the key part of the door lock to the electrical switch has come off ,no doubt the plastic clip that holds it has broken
Anonymous
  • 166 Answers
  • Posted on Nov 18, 2009
SOURCE: The central locking of my Hyundai do not lock or
might be the motor, that needs to be checked, it could be the cables giving power to that motor or could be the unit responsable of sending power, get a electrical diagram for the sistem and check every step for the voltages expected.
hope this helps
1helpful
2answers
On a 2001 Ford Focus SE five speed where is the automatic door lock relay located
Sorry Andrew , no BCM on this vehicle . The Central Security Module is incharge of power door locks . Central Security Module For additional information, refer to Section 419-10 .
The central security module is equipped with a battery back-up which holds the programmed transmitter(s) memory in the event of the vehicle battery disconnection.
Principles of Operations The Door Switch Lock Function When a door lock switch is moved into the lock position or a door lock cylinder is rotated to the lock position, the door lock switch grounds the lock circuit input to the central security module. The central security module then provides 12 volts to one side of the door lock actuators contained in the door latch unit and simultaneously grounds the other side of the door lock actuators. This completes the door lock actuator circuit, causing the door lock actuators to rotate a cam assembly, which then locks the doors.
The Door Switch Unlock Function When a door lock switch is moved into the unlock position, the door lock switch grounds the unlock circuit input to the central security module. The central security module then provides 12 volts to the opposite side (relative to locking the door) of the door lock actuator(s) contained in the door latch unit and simultaneously grounds the other side of the door lock actuator(s). This completes the door lock actuator circuit, causing the door lock actuator(s) to rotate a cam assembly in the opposite direction, which then unlocks the door(s). The 12 volts which the central security module provides to the door lock actuator(s) are provided to each door lock actuator from the individual pins on the central security module connector.
Keyless Entry When a remote transmitter button is depressed, it transmits the appropriate command to the central security module as a radio frequency. The central security module receives the command from the remote transmitter through an antenna, which is incorporated in the central security module.
When the central security module receives a command from the remote transmitter, it then sends the appropriate output to control the desired devices. These outputs devices include:
  • The front and rear door lock units.
  • Central timer module (CTM).
  • The liftgate release motor.
  • The right and left side turn signal lamp(s).
The central security module sends a signal to the CTM when courtesy lamp illumination is required.
Computer Operated Locks Each front door lock actuator contains a bipolar motor that controls the lock and unlock linkage. The lock/unlock lever of both front door interior handles use linkage to actuate the lever lock switch located inside each front door lock actuator. Each lever lock switch remains in the unlock position until lock/unlock lever of the interior door handle is moved to the lock position. This action toggles the lever lock switch to the lock position. The central security module uses only one electrical input for both lever lock switches. The central security module cannot determine whether the driver or passenger door lever lock switch was actuated. Therefore, actuating the lock feature from either front door will have the same affect of locking all doors. Actuating the unlock feature will not unlock any other door.
The door lock control switches for both front doors also use only one input to the central security module.
Both rear passenger doors contain a rear door lock actuator that controls only electric lock or unlock of the door. Actuating the lock/unlock lever at either rear passenger door will have no effect on other doors.
The panic feature of the remote transmitter sounds the vehicle horn when the vehicle is not equipped with anti-theft. If the vehicle is equipped with anti-theft feature, a separate horn is sounds for the panic feature.
Door locks on the passenger side will not open with the remote
The master central locking module may be faulty. If the remote still operates the drivers side door lock and it will manually unlock with the key, it's possible the central lock mechanism in the drivers door is no longer sending a signal to all the other doors to lock/unlock. If all the door locks operate when you manually unlock the drivers door, the issue may be the remote receiver unit. It would help to know what car you're driving as some vehicles have inherent faults that are common and there is usually a go-to method of rectifying the problem.
Hi i have Cherokee sport 2001 and central door locks not working, at the same time all passenger windows cannot be open only i can open from driver side console. few days back all the door locks start
Try unplugging the passenger door module from the wiring harness. Module may be bad. I see one screw holding it with tabs at the other end. You should be able to pull it up without removing the door panel. I see there are modules online for less than $40.
1helpful
1997 toyota corolla drivers door lock not working...
http://www.manualowl.com Hope this helps! Jimmy
4helpful
2answers
The driver side door does not unlock - can only (central locking)
Hi:
It is extremely difficult to remove the door panel with the door closed. You mentioned that you can unlock the door with a key, so does the door still open and close once unlocked? You most likely just need to replace the power door lock solenoid, as when they fail, they usually sieze up, and make manual lock unlocking difficult.
Electric door locks only work from driver door
hi, does the drivers door unlock and lock all the other doors if it does then you may find that a clip or connecting bar has come off the passenger door lock, you would need to take the door panel off to check,
If how ever the passenger door dont lock and unlock via the drivers door then you would need to buy a new central locking motor for the passenger door..
Your best option would be to remove the passenger side door panel and get someone to lock and unlock the drivers door whilst you look at the passenger side and have a look to see what parts are moving this should then give you a good idea of the parts that could be damaged
2helpful
4answers
1helpful
Bora central locking problems
Hi had a skoda with problem like this one changed lock fixed it
Jeep grand cherokee central locking system
If all the doors do not lock or unlock when using the passenger side switch, then the switch itself is probably bad.   If the passenger side switch locks or unlocks all the other doors except for its own, then the power lock solenoid inside the door is bad or jammed.  If it is jammed, try locking and unlocking the door manually while activating the switch to work its way free.
Faulty central locking
Get in passenger side and unlock drivers side manually, this will unlock the 4 doors.
Top Hyundai Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Hyundai Expert? Answer questions, earn points and help others
