Question about Panasonic RR-US500
Panasonic RR-US500 my computer operating system is windows vista and i can't download anything from the RR-US500 because it's suppose to work wirh windows xp and i was wondering if there is an update available for the driver or for thevoice editing software so that it can work on vista ?
Posted by mariiii on
Anonymous
After installing the software update from Panasonic, plug your recorder into the computer. Go into 'Control Panel' and select 'Hardware and Sound'. Then Select 'Device Manager' and select 'Universal Serial Bus controllers'. You should have a device for 'Panasonic IC Recorder', it might be flagged yellow, right click on it and select 'uninstall'. Unplug your recorder from the computer, replug your recorder into the computer, the Device Manager screen will refresh and you should have 'Panasonic IC Recorder' back in the list. Try the Voice software, you should have in the drive list 'IC recorder'. Transfer your files.
It worked for me,
Pierre
Posted on Nov 19, 2008
Need Windows 8.1 Driver for Panasonic RR-US500 IC voice Recorder
go to Panasonic web page , find your model voice recorder , find a download compatible with your win operating system and down load
Jul 07, 2018 | Panasonic Audio Players & Recorders
My PC can't recognize my Panasonic IC recorder RR-US500
Which operating system are you using? This recorder has known issues with windows vista and windows 7 as well as Mac OS.
If you're using one of the above windows operating systems, try right clicking on the installer (setup.exe) file, select "properties". When the properties windows opens, select the compatability tab, and choose windows XP SP3 from the drop down menu, as well as click the box next to "run this program as administrator". That should run the installer as though you are running windows XP, and it should work.
Jun 06, 2012 | Panasonic Audio Players & Recorders
I just plugged in the RR-US500 to my HP dv6 laptop and it won't sync. Can anyone help?
necesito descagar el sofware M66291 GP de RR-US500 para windows 7 en peru!!
Sep 07, 2011 | Panasonic RR-US500
Hello i am having problems using the panasonic RR US500 recorder on my mac
Welcome to Fixya. The problem that your experiencing is happening because the RR US500 is only compatible with Windows Operating System Platform. Unfortunately you wont be able to use this on your mac.
Thanks
I need software for Windows XP for Panasonic RR-US470
The only place you can get it free is from peer to peer file sharing which can lead to viruses and copyright infringement. Otherwise you can buy a download straight from Microsoft's website.
May 14, 2009 | Panasonic RR-US470 Handheld Digital...
Want to download free software of window vista latest edition
you wont be able to download any free windows operating systems, also if you have an xp laptop at the moment then vista would make it run slower if anything
Dec 10, 2008 | Microsoft Windows XP Professional With...
HP OJ 5610 Drivers-? Can not install printer.
In this case, there's no mystery as to the cause of the problem. You will be unable to use this printer with your operating system because there are no existing print drivers that work with 64 bit Vista. Your printer will work with Windows 98, Windows 2000, and Windows XP, but not with Vista at all.
You have only two options...use a different HP printer that will work with Vista, or get a PC that has one of the supported operating systems on it and connect your current printer to that PC.
Sorry. I know this isn't the answer you were looking for, but that's the best I can do until the proper drivers become available.
Oct 05, 2008 | HP Officejet 5610 All-In-One InkJet...
Voice Editing 1.0 premium Update for Vista
Try this
Uninstall the software.
Reinstall the software
It worked for me,
Pierre
Jul 27, 2008 | Panasonic RR-US500
Panasonic RR-US500 Logo
3,622 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
John Wardlow
John Wardlow
Level 1 Expert
Ekse
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
