Car will not start, just makes a whirring noise when I try to start it,the check engine light comes on.
There is most likely a problem with your starter -- if it is not grabbing the engine to turn it over when you turn the key, the starter motor will spin (giving you the whirring noise) but the engine will not move. First things first ... have someone turn the key, and hit your starter with a stick or something ... sometimes this will free up whatever part is not working proper5ly, and you won't have to replace your whole starter. If hitting your starter doesn't work ... and if you are good with cars, try replacing the starter and see if that helps.
Hopefully those will help ... if not, you will probably have to take the car to a mechanic to get it fixed, as there are several other parts that could be causing the issue -- but they are hard to get to and require some experience to know what you are looking for.
