Question about Whirlpool GHW9150 Front Load Washer
GHW9150PW1 Won't Spin
My washer won't spin. I don't know how to access the inside of my front load washer to check the motor coupling. Any help would be greatly appreciated.
Posted by KAP112786 on
  • 3 more comments
  • KAP112786 Oct 31, 2007
    Okay - I have to check the door and check for codes. When I get it - I'll post it. Thanks for the reply.
  • KAP112786 Nov 05, 2007
    The codes "H' and "F" are appearing.
    The codes "H" and "F" appear.
  • mcmaples Feb 12, 2008
    F11 shows up when I try to start the washing machine. What do I need to do?
  • Anonymous Apr 26, 2008
    won't spin.
Anonymous
    Problem Solver:
  • 19 Answers
Check the door lock
Posted on Oct 31, 2007
  • Anonymous Oct 31, 2007
    did u get any codes
Won't drain the water anymore
Drain motor is usually located on the bottom of the machine. Hopefully you have an access panel separate from the main door panel. Should be a hose coming in and a hose going out. Put the machine in spin cycle and see if you can feel the pump spinning. If the pump is very hot, chances are something is blocking it. They will usually have an access port that can be opened up just for this reason, be ready to catch the water when you open it up, and please turn the machine off first. If you get no sign of life from your pump it may have died. Also check for any blockages in the drain lines. All of this should be easily accomplished with a couple screwdrivers and towels
Apr 10, 2013 | Baumatic BTWM4 Front Load Washer
Low rumbling noise and washer won't spin
Remove access panel and check to see if the belt is on.
Nov 12, 2012 | LG WM-2277HW Front Load Washer
My candy GOFS262 washing machine is filling the drum to the top with water on every cycle but doing nothing else after that, the clothes jst sit there in the water, I've left it to see if something...
see this causes and fix it. God bless you
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission.
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Oct 11, 2012 | Washing Machines
My roper top load washer model rtw4440vq fills with water but wont wash, spin or drain
Sep 30, 2012 | Roper Washing Machines
The machine doesn't spin properly and doesn't drain the water
Lid Switch Assembly If the washer won't spin the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Motor Coupling If the washer won't spin the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission. Another common problem is the lid switch.
Drive Belt If the washer won't spin, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin properly.
Door Lock Motor and Switch Assembly If the washer spin the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Drive Block If the washer won't spin the drive block might be worn out or may have come loose. Underneath the agitator the drive block connects the inner tub (the one that spins around) to the transmission. If the drive block wears out the transmission shaft will still spin but the tub may not - or it may spin slowly. This also usually causes a lot of noise. The drive block is relatively easy to replace.
Clutch Assembly If the washer won't spin, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Clutch Band kit If the washer won't spin, the clutch band kit might be worn out. The clutch makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. If the washer won't spin, this clutch band kit may need to be replaced.
Drive Motor If the washer won't spin the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged It will have to be replaced.
Tub Bearing If the washer won't spin the tub bearing might have seized. This is a common problem and relatively easy to replace.
Tub Seal and Bearing Kit If the washer won't spin the tub seal and bearing might have seized. This is a common problem and relatively easy to replace.
Bearing If the washer won't spin the bearing might have seized. This is not common. The bearing doesn't require any normal maintenance. They generally go bad when the tub seal fails and allows water to leak past into the bearing.
Basket Drive If the washer won't spin the basket drive clutch might be worn out. The basket drive sits on top of the transmission and engages with the inner tub. If the basket drive wears out the tub won't spin.
Basket Drive Hub Kit If the washer won't spin the basket drive hub might be worn out. The hub is a set of plastic gears underneath the agitator. The basket drive hub kit is easy to replace with standard hand tools.
Transmission If the washer won't spin the transmission might be worn out or defective. There are numerous more likely causes when a washer won't spin, which should be checked first.
Sep 28, 2012 | Hotpoint Washing Machines
Whirlpool top loader washer will not spin
Could be one of several different things depending on the age and model. If its less than 10 years old and is a top load washer its probably a motor coupling (connects the motor to the transmission kinda like a belt) or lid switch. If the water is draining out but the washer is not spinning its probably the motor coupling. If it still has water in it and won't spin, its probably the lid switch. If your washer is a front loader there could be several things going on. Hope that helps.
Aug 29, 2011 | Whirlpool Washing Machines
Whirlpool GHW9150 Front Load Washer Logo
185 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
