Question about Texas Instruments TI-89 Calculator
X and Y axis disappeared
I recently loaded a few games onto the ram on my calculator and when I went to graph, there was still a visual from the game on the screen. I pushed clear all I think and the entire screen was empty. Now, when I type in equations to graph, it still graphs them correctly but there is no y or x axis. Please help me, this is pissing me off.
Posted by chadpad3 on
  • Anonymous Feb 02, 2009
    did the same thing or my friends messed it up.
Anonymous
If you are using the TI 89 titanium Go to your graph press f1 go do to last option (format) you can turn on your x and y axes there
Posted on Feb 20, 2010
Anonymous
You hit 2nd Zoom then turn go down to Axes On and hit enter to turn it on.
Posted on Nov 04, 2008
Anonymous
  • 3 Answers
The easiest fix is to reset the calculator's defaults. Press 2nd MEM (the 6 key), then F1, then select RAM then Default. Hit enter twice to confirm.
Posted on Nov 10, 2007
matzieman99
Go to window. check that the x any y coords max and min are to show the coordinate plane.
default
xmin=-10
xmax=10
xscl=1
ymin=-10
ymax=10
yscl=1
keep the res's at 1.
if that is correct try this.
hit 2nd zoom(format)
and make sure axeson is black. if it is not go down to it and hit enter over it. if that dosnt fix it i think ur screwed :)
Posted on Mar 24, 2009
Anonymous
Delete that program
Posted on Mar 19, 2008
How can you graph a spherical shape when z axis is predeined as z(x,y) ?
You need to set the graphing mode to 3D. In 3D graphing the function is represented as z(x,y)=function of the variables x and y.
Here are a few screen capture to show you how to set the thing up.
Read the calculator manual.
On the last screen are the parameters to change the point of view.
Aug 29, 2014 | Texas Instruments TI-92 Plus Calculator
My TI-84 PLUS calculator wont show the graph after i type in an equation. please help!
You need to fix your graph so that it shows the correct y-axis and x-axis.
It works best if you press the zoom button and then scroll to find the ZoomFit option.
Then the graph should show up.
Jun 15, 2011 | Texas Instruments TI-84 Plus Calculator
The axes have disappeared in graph
I would try making sure they aren't turned off. Do this by pressing [star] [y=] this will take you to the y =
page, then press [f1] arrow down until format is highlighted and press [enter], this should open up a menu
with "axes........." as one of the options use the arrow keys to highlight the axis option and press [enter]
this will open up a menu to turn the axis "on" or "off", highlight "on" and press [enter]. Press [esc] to exit
the menu.
Mar 07, 2011 | Texas Instruments TI-89 Calculator
My Graphing calculator has no x or y axis. Its all Blank.
Press the 2nd Button then the ZOOM button. Make sure that AxesOn is highlighted. If not, move your cursor down until you on AxesOn and press ENTER.
If AxesOn is highlighted, then it is probably your window. Press ZOOM, then 6.
Jun 03, 2009 | Texas Instruments TI-84 Plus Calculator
Dim Mismatch
Hit 2nd then the Y= button and you'll get to the stat plots. make sure they are all turned off, sometimes random programs (ie. games) will turn on stat plots and screw up your other programs and graphs.
Sep 25, 2008 | Texas Instruments TI-84 Plus Silver...
Problem Running Games - no UMD symbol on console
I THINK THE OPTICAL PICK UP OF UR GAME HAS BEEN FAILURE , JUST CHANGE IT FROM ANY NEAREST SERVICE CENTER
Jan 18, 2008 | Sony PlayStation Portable (PSP) Console
Will Not Graph 2 eqations on one set of axis.
mine did the same thing and i had to reset it. hit 2nd and then the plus key to bring you to the memory menu and hit 7 for the reset. Then press 2 for defaults. That should fix the problem. If not press 1 for All Ram under the reset menu. Hope this helps
Jan 05, 2008 | Texas Instruments TI-84 Plus Calculator
Texas Instruments TI-89 Calculator Logo
5,365 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Ekse
Paul Bade
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
