My derbi wont start no matter i kick or jumpstart it. it worked before the winter and now it is leaking gas too. please help me out
SOURCE: help. my sons derbi send r 125 wont start. all
have you checked your air filter. If its dirty wash out with air filter cleaner or petrol and replace.
SOURCE: Kick start for Derbi GPR
No kick start is availabe as an add-on. You will need to install a new battery.
SOURCE: i have a derbi senda r xtreme 50cc, it only starts
Sometimes it stats and runs, this clears that there is actually, not the problem.But suddenly it will not star, his indicates problem with connections, either something i getting loose or short. You need to test h voltage to battery,stator[voltage regulator] and starter when you face this no start problem. IF all this parts show correct voltage, then inspect fuel pp n spark plug voltages.IF that also checked ok,then get the,ignition system checked, ignition start switch is getting Short and check compression for ignition cylinders ,if compression differs on any cylinder then that is the problem and needs to be replaced.-------- Getting, this possibilities checked will help.Thanks.Helpmech.
SOURCE: my derbi wont start at all, no matter what i try...
remove carb and clean the jets etc and replace the fuel as it will be bad !! new plug be good !
Testimonial: "I have cleaned the carb and the air filter. new gas and the spark plug works. Everything is looks fine but i cant start it..."
