Question about Sony SDM-HS75P/S 17" LCD Monitor
SCREEN GOES BLACK OFF AND ON .....
Posted by Audift on Oct 17, 2007 Report abuse
My Sony SDM-HS75P Silver 17" LCD Monitor turns black during use, usually have to unplug and replug (sometimes more than once) for it to come back.  This happends at least once per hour.  It´s not completely black, although almost, you can see it but it´s extremelly dark.
Please advice, help!!!
Solution #1 posted on Oct 31, 2007
By  Mitch_846
Rank: Not rated
Rating: 0%, 0 votes
I'm having the same exact problem now and have had to turn off and on numerous times with it working for a short while and the the screen goes blank again although the power is still on with the monitor.
Please someone help us .....
Posted by Mitch_846 on
Anonymous
It's a common problem with sony hs75p
the problem is with the power board's transistor in the monitor
people might try some stuff and may get some results, but trust me it's all luck...
i had the same problem, so i gave my monitor for repairs as it was under warranty and the culprit was the power board (sony calls it the 'A' board). The only problem is u need to have patience as u are dealing with sony here >_>.... i mean, i got my monitor back, but after 2 tries and with many dead pixels and analog signal being greenish...well atleast the DVI port worked fine >.>, which they said wasn't their fault ( i was like...riiiight, so the dead pixels generated all by themselves, huh?..btw if u are wondering...before giving my monitor...they checked the monitor and it's written in the receipt that the monitor had no dead pixels).... so dont be surprised if ur monitor comes up with another problem, after giving ur monitor for repairs to sony >.>
in any case it's 'A' board problem
Posted on Jun 23, 2008
Anonymous
I had the same problem for about a week and solved it yesterday by downloading the latest driver by NVDIA who makes my video card (NVDIA GeForce 6200).
I had previously updated the latest Sony driver for the monitor. It did not solve the problem but could be part of the solution in conjunction with the new video card driver.
Posted on Mar 12, 2008
Sony sdm-hs75p no power?
If you wish to get some details; check the site linked here. Pull up older posts.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
May 19, 2014 | Sony SDM-HS75P/S 17" LCD Monitor
Sony sdm hs75p doesn't power on
try replacing the back light inside the monitor.
Aug 15, 2010 | Sony SDM-HS75P/S 17" LCD Monitor
Does a vista driver exist for sony SDM HS75P?
No but you can attempt to use the default driver or the windows 2000 one. I have found that a few of the windows 2000 and xp drivers do work for things that vista doesn't have a driver for
Feb 12, 2010 | Sony SDM-HS75P/S 17" LCD Monitor
Pwr Led blinks orange, with black screen (monitor is connected to computer)
Take off the monitor and hook up another known working monitor to the computer and turn the computer and monitor on. If the computer turns on with video then you know the original monitor is bad and would need to be replaced.
Jan 04, 2010 | Sony SDM-HS75P/S 17" LCD Monitor
Sony sdm-hs75p runs for 5 odd minutes then screen goes blank?
h_e_l_l_f_i_, Have you performed the flashlight test after the screen goes "BLANK" ?? No!! You will not find the "flashlight" test listed in the OWNERS manual!! The test is a quick evaluation of the STATE of the units "switch-mode-power-supply". Did you repair the power supply to get online to fixya? The more info you tell me about your LCD monitor the better I can assist you. Is the unit really "BLANK" or is it just "BLACK"?? Can you SEE the WIN-desktop when a bright "flashlight" is held 1" from the screen at different angles? If you can see a faint image being displayed it means the SMPS is in partial shutdown and still powering the VGA to LCD interface board. If unit is both BLACK and BLANK, then SMPS is likely in full shutdown mode! I will assume that when you stated "runs" for 5 minutes, that it would display normal text and graphics as usual and NOT be wearing a pair of NIKE's runners footwear? Yes! From your description it would lead me to think that your SONY has a SMPS/INVERTER problem. You failed to state the age and or approximate TOTAL "ON" hours the unit has. (hrs/day x 350days x Years since DOM). It makes a difference in whether I tell you to trade up to a wide screen or have it repaired(refurbished with new SMPS/INVERTER or just rehab the SMPS on your own. hellfi, surely, after reading this you WILL go to YOUTUBE, (just fyi) and view some of the longer video clips of "LCD monitor disassembly" and typical "LCD monitor repair"!! You WILL be impressed at how much you will learn about how "the black screen of death" is dealt with. If this response helps in any way, please rate it on fixya. 12fixlouie lmistyrel @ aim.com Get back to me if further assistance is required asap!!!
Nov 23, 2009 | Sony SDM-HS75P/S 17" LCD Monitor
How do i reset my SDM-HS75P monitor information box keeps popping up
Press once the Input button. The menu appears. Press the Input button again and hold it. Now this is reduced to the problem of blocking the Input button (holding it with something). (Not very technical but then again neither is the restart when the computer blocks :D) Cheers
Oct 28, 2009 | Sony SDM-HS75P/S 17" LCD Monitor
Monitor Goes Black or wont turn on
So, the problem is not from inverter board. I used to repair LCD flat screen from Dell. I found that it is a broken lamp. It is not big but very small crack. You might double check it again.
Thank you,
Mar 11, 2008 | Sony SDM-HS75P/S 17" LCD Monitor
Monitor goes Black off and on .....
Oct 31, 2007 | Sony SDM-HS75P/S 17" LCD Monitor
LCD Monitor Goes Black during Use
I had the problem sometimes, but then I connected a second computer to the analog input and found out, that the screen didnt turn black but switches between the inputs on an on.
I found out that the "input" button seems to be short or damaged, as the behaviour was invertable by pressing the button. I blew into the button some times (a very naive solution, yeah) but it worked, the switching stoppped.
Oct 17, 2007 | Sony SDM-HS75P/S 17" LCD Monitor
Sony SDM-HS75P/S 17" LCD Monitor Logo
744 people viewed this question
Top Sony Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
