2006 BMW X5 Logo
M
Mark Richards Posted on Mar 28, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cant tune my radio in on my X5
Their is a fussy sound in the background but i cant tune the radio, sometimes get a weak signal
h2oskierfl95
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 59 Answers
  • Posted on Mar 28, 2014
h2oskierfl95
Expert
Level 2:
New Friend:
Cheetah:
Answers
59
Questions
0
Helped
11771
Points
256
This is probably due to a poor antenna connection. Assuming this is the factory radio, you will want to check the connector in the rear cargo area (drivers side pillar).
1helpful
How do i fix faulty dab radio
If your signal keeps breaking up , you might be in a poor reception area , Check if you get the same problem on other DAB stations you are tuned into.
I got a 91 chevy pick up with a cilfford, the radio works but hardly any sound comes out of speakers. I got a new radio and its the same. All speakers play buy sound is very low. I was told it was do to...
posted 6 times.
run new wires from new radio to speakers
or bench test your radio (easy) with your speakers.
if still low the speakers are bad or just dirt cheap , car speakers.
try new speakers, if weak now the wires are bad, try new wires
id still weak the radio is bad. (or just a cheap radio)
and define weak, to me most radios are way too load.
but to others, all are weak until 1000watt amp is added.
weak is a relative term. as is hardly any.
do not quote persons guessing, its just a wild guess. they can see car either, do the tests your self and find TRUTH.
to bench test, (modern way)
1: 12vdc 1amp power pack, or battery 12v. and ground.
2: connect up USB mem,. with some mp3s. on stick.
3: connect one good speaker (KNOWN GOOD)
to one of 4 speaker lines. (2 wires)
4: push play, does it sound good, yes, move to next speaker port.
ok , the radio is good. so
try it in the car, is it now low volumn
yes, then move that test speaker to the car speaker that is low.
still low, yes, then the wiring is bad.
easy huh?,,, takes only , a test speaker.
if no usb use, cassette, if no that , use CDDA disk( store bought real)
if none of that us the radio to test. connect a test antenna.
tune in Am or fm. bam.
I have an issue with my bmw x5 e53 regarding pixel loss on the radio and instrument cluster. Its begining to be a safety issue because I need to read data of the screen but makes it impossible sometimes...
there is a plsce in USA that will repair the radio or istrument cluster for under $200. Yuo can find them on ebey just put in X5 instrument cluster repair and they should pop up. I had my radio dislay repaired and they did a great job.
Aug 24, 2010 • 2005 BMW X5
Radio + CD player works, no sound
Check you antenna wiring. If you have a weak signal the mast may be loose or the mount can be too. Check for corrosion between the body and the mounting area as well
6helpful
3answers
Radio has no sound
Hello, I've the same problem... however my sound is likely there when I restart the X5 after an hour or so, but it is as likely to disappear during the minutes that follow, often when the car is shaken.
There is then a fair chance to get sound back as soon I drop the phone after a phone call (but it does not always work).
--> My guess is that it is the line of the Phone "mute" signal that brings every sound source down thru a bad contact or so.
BMW wanted to replace the radio for 900 €. Hmm a lot of money for a bad conatct if my guess is right.
Gary
Top BMW Experts
vince
Steve Sweetleaf
Steve Sweetleaf
old marine
old marine
Are you a BMW Expert? Answer questions, earn points and help others
