Question about Sanyo DS20930 20" TV
Sleep timer on
I have a Sanyo ds20930.  I can program the tv to go OFF @ the time I want, but I can't get it to TURN ON in the morning.  I grabbed the remote wrong one day & pushed a wrong button, & now it shows the time &  day of the week, But I can't get back to the screen that lets me program it to turn ON in the AM
Posted by ToothAngel on
  • ToothAngel Oct 31, 2007
    Yes, but will try again.  How long should I leave it unplugged?
    If that doesn't work, can you recoomend something else?
  • ToothAngel Nov 01, 2007
    Yes, I have the right model #.  This is an OLD tv set.  I did try to leave it unplugged, that didn't work.  Anything else to try?
Anonymous
  • 59 Answers
Did you try to unplug and start all over again ? set time and day etc...
Posted on Oct 31, 2007
  • Anonymous Nov 01, 2007
    are you sure you have the right model number
Sanyo dp55441 - wont come out of sleep mode. every hour a msg comes up tv will turn off in 1 min. how do i turn this off? pls and thank you
hi go into the menu on the tv scroll down to picture setting look for sleep timer select off
regards
shaun
Jan 31, 2014 | Sanyo Televison & Video
I can't set up my wii on my Sanyo DS20930 TV
Click here to download the user manual to your TV. It has all details.
Aug 26, 2012 | Sanyo DS20930 20" TV
Why does my tv turn off automaticly
Some tvs have a sleep timer on it and if it is accidently programmed the tv will turn off at a certain time. You may want to look at the users manual for more info. Or call a local place that fixs tv's for some more input before paying someone or getting a new tv. I had a tv once and it did the same think. I had to get into the menu with the remote and figure it out it had something to do with a set sleep timer so the tv would shut off at a certain time if the timer was set. It sucks if you dont have a remote though hopefully you do. Good luck. M Some tvs have a sleep timer on it and if it is accidently programmed the tv will turn off at a certain time. You may want to look at the users manual for more info. Or call a local place that fixs tv's for some more input before paying someone or getting a new tv. I had a tv once and it did the same think. I had to get into the menu with the remote and figure it out it had something to do with a set sleep timer so the tv would shut off at a certain time if the timer was set. It sucks if you dont have a remote though hopefully you do. Good luck. M Some tvs have a sleep timer on it and if it is accidently programmed the tv will turn off at a certain time. You may want to look at the users manual for more info. Or call a local place that fixs tv's for some more input before paying someone or getting a new tv. I had a tv once and it did the same think. I had to get into the menu with the remote and figure it out it had something to do with a set sleep timer so the tv would shut off at a certain time if the timer was set. It sucks if you dont have a remote though hopefully you do. Good luck. Malena!!
May 10, 2012 | Vizio Televison & Video
HOW CAN I FIND THE CLOSED CAPTION ON SANYO TV MODEL DS20930
User manual:
http://www.retrevo.com/support/Sanyo-DS20930-TVs-manual/id/17567dj485/t/2/
See page 6 (CAPTION button on the remote) and page 14 on how to use Closed Caption functions.
Dec 30, 2010 | Sanyo DS20930 20" TV
Change input without remote
Go to menu on front of tv, scroll down to source/input heading.Use the volume or channel select buttons to change the source
Sep 14, 2009 | Sanyo DS20930 20" TV
SANYO TV
This plug no solder, you need a RCA connector # SK25FCON. THIS PLUG ACCEPT SOLDER
Oct 25, 2008 | Sanyo DS20930 20" TV
Ds20930
Try resetting the settings. In the menu there should be a settings option. Reset them to default of facory settings. Here is a website that mayl help you with this.
Let me know if this works out for you.
Sep 11, 2008 | Sanyo DS20930 20" TV
Broken remote, want sleep timer
Only if you can do this in the the menu from the front of the set. Some will let you but others do not include this in the menu . Then a remote will be the only way . You can go to www.replacementremotes.com to see if you can purchase a remote for your set . Good luck
Feb 27, 2008 | Sanyo DS20930 20" TV
Sanyo tv ds20930
Does your screen light up or picture comes before it turns off? This could be from your X-ray protection feature, you will have to check the power supply output voltages.
Jan 30, 2008 | Sanyo DS20930 20" TV
Sanyo DS20930 20" TV Logo
190 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
