My son wrongly connected the terminals on a battery in a 2006 Toyota Landcruiser non turbo diesel wagon. I saw the headlights were going on & off & he noticed his mistake & disconnected the battery. Since this happened, there are no dash, stop, tail lights or blinkers working. We've checked all small fuses & they're fine.
SOURCE: 1997 GMC Sierra p/u. Brake light & blinker out. Lamp & fuse ok.
you probably got the wrong bulb
those are usualy a different number higher wattage, they look exactly like an 1127 but are a 2027 or even a 3027 check the bulb base it has the number printed on it
SOURCE: 1991 Toyota Camry, tail lights and dash lights don't work
Have you looked under the hood? There are more fuses under the hood. Is your dimmer turned down on your dash lights?
SOURCE: Brakes Lights dont work on a 2006 Chevy Silverado
I've worked on these the first drove me crazy. its the turn signal switch every thing runs thru these. head lights, turn signal, brakes. except the third brake light. it runs directly from the brake switch. go figuare
SOURCE: i have a toyota prado 2001 turbo diesel and instum...
how to change car audio toyota prado 2001
Hi Kaza R, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
Sorry Dana Turner, what other details would you like added?
