Question about Brother MFC 420CN All-In-One InkJet Printer
Brother MFC-440CN printing error
I had a paper jam a while ago and an "unable to print 34" message came up. I checked the manual and it said any kind of message with "unable to print #" meant something was stuck in the printer. I can't see anything else and it looked like I got all the paper out. I turned it off and unplugged everything and it eventually turned into an "unable to change 32", but soon after it changed to "unable to change 34". So I have no idea why it kept changing, but it won't print anything and I can't use any of the other functions. It won't even turn off. I asked the store where it was bought(it was a christmas gift) and they said to call the brother support number and if they can't help me then I'd have to send it to them. So I don't know if there's anyway I can fix it or if I should just go ahead and send it in. Thanx!
Posted by angelicasong on
  • 1 more comment
  • Anonymous Jan 08, 2009
    I am out of guarantee and need my printer to work badly. Any clue would be greatly appreciated. Thanx!!!
  • TEMDC Mar 02, 2009
    i HAVE THE SAME PROBLEM, TRIED EVERYTHING, OUT OF WARRANTY WHAT TO DO
  • rhusker Apr 14, 2009
    Constant "paper jam" without really a jam. After resetting it won't print until the heads are recleaned. I haven't printed 50 sheets total. Office Depot won't allow return, must send back to Brother.
lukystreik
    New Friend:
my problem was the positioning of the print head. I opened the scanner cover, pressed the cover-closed control-switch and wait until the head begins to turn back to park position at the right side. When it began to move around the park position i pressed it to the right side. After that, all was ok.
I demonstrate it in a youtube video
http://www.youtube.com/watch?v=iLyVqPwsQtU
good luck
lukystreik
Posted on Mar 27, 2011
Anonymous
    New Friend:
I had the same problem. It DID have a paper jam, I opened the Back cover to no avail, and found the paper jam when I lifted up the scanner from the bottom. I unplugged the printer twice and plugged it back in. Finally it did a cleaning cycle and everything was OK, other than using up some outrageously priced ink. I skimmed thru the HTML owner's manual but couldn't find how to initiate a cleaning cycle manually. I have a suspicion that if you can get it to clean itself the problem will go away.
Posted on Dec 03, 2009
wychuchol
I encountered the same problem. I just took all what's left of the paper from inside of the machine and than took off this plastic cover from the back of the machine. Than "unable to print 34" message disappeared, and "receiving data" message appeared on the lcd. Without the plastic cover machine released 3 pages and showed this message about paper fed. Than I put the cover back on it's place and pushed the green button (colour). Than again "receiving data" and mfc 440cn just printed requested documents. I have no idea why it was so simple, maybe i was lucky, no harm in trying after all, good luck!
Posted on Nov 07, 2007
Mix-it-up
  • 832 Answers
If its guarantee send it in.
There might be some paper left in the machine and/or the encoder strip which gives the printhead the position was lifted out of position.
In case youll end it in they will change the cover of the printhead to avoid this error in future.
In case you are out of guarantee plz post it here as a new prob! Ill give you the clue then.
Posted on Oct 31, 2007
"UNABLE TO PRINT 50" appears
Error: -------- Unable to Print XX
Problem: ------------ The machine has a mechanical problem. -OR- A foreign objects such as a clip or ripped paper is in the machine.
Solution: ------------- Open the scanner cover and remove any foreign objects inside the machine. If the error message continues, do one of the following: ?? (MFC-440CN only) See Transferring your faxes or Fax Journal report on page 139 before disconnecting the machine so you will not lose any important messages. Then, disconnect the machine from the power for several minutes and then reconnect it. ??
May 22, 2011 | Brother MultiFunction Center MFC-440CN...
UInable to print 50
check
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/002400/000090/faq002490_000.html?reg=us&c=us&lang=en&prod=mfc845cw_us
Apr 19, 2010 | Brother MultiFunction Center MFC-440CN...
Unable to clean 50 error
I have a Brother MFC-440CN fax machine and I am receiving error message "unable to clean 50". Can anyone help me to fix this error problem
Jan 13, 2010 | Brother Office Equipment & Supplies
Error message ''Unable to Print 4F''
How to repair error "print unable 4F" in the Brother dcp-135c .
thank alot.
Jan 06, 2009 | Brother MultiFunction Center MFC-440CN...
Printer ERROR "Unable to Print 50! Unable to Print 30!" ???
WONT PRINT UNABLE TO PRINT , PAPER JAM
CLEANED PAPER JAM, CANT SEEM TO FIND ANY THING MORE TO DO TO IT
Sep 04, 2008 | Brother MultiFunction Center MFC-440CN...
"Unable to Print 50" BROTHER MFC-440CN
my brother mfc-440cn printer says, "unable to print 51" on the screeen after if off (which it woudn't let me do. I had to unplug it. It just won't work.
Aug 26, 2008 | Brother MultiFunction Center MFC-440CN...
BROTHER MFC 240 C
same issue:
http://www.fixya.com/support/t294185-brother_mfc_240c_change_unable_50
Mar 31, 2008 | Brother MultiFunction Center MFC-440CN...
Printer message: Unable to Print
5A: encoder disc or encoder strip or main circuit board or printhead circuit board or power supply defective!
Sorry, cant be fixed by yourself!
Feb 20, 2008 | Brother MFC-440CN InkJet Printer
Brother MFC 420CN All-In-One InkJet Printer Logo
5,504 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Jim Keysor
