Battery was replaced and heater stopped working. A/C works but heater does not. Honda claims just a coincidence.
SOURCE: Hi, I replaced my honda
In the newer Honda's there is a lock code on the radios when they lose power the code kicks in to prevent theft the reset code should be in your owners manual if it isn't call your locale Honda dealer.
SOURCE: honda pilot blower motor stops
When you removed your motor, did you check in the area where the motor mounted to see if there was an obstruction? It could be a bit of insulation or paper... just a thought.
SOURCE: radio error Honda Pilot code
the code should be with your owners manualy its on a card the size of a business card.there will be # s on it, make sure you follow directions in manualy on how to enter code,also you might be able to call dealer, give them your cars vin # and they sometimes will give u a code.good luck.
SOURCE: fix honda pilot 2005 fan relay
It can be the A/C switch causing this, but not likely. Make sure to turn the A/C off when you stop. If it still does it after turning the A/C off, replace the thermal relay.
SOURCE: 2003 honda pilot, remote control doesn't work even
did the light blink when it worked? It may need to b reprogrammed. check the owners manual, it should tell you how to program. If the fob is dead, check ebay for a new one, usually 50 bucks and the reprogram
