Question about Hotpoint WMA58 Front Load Washer
Hotpoint aqurias washing machine
The brushes are worn on 1 side more than the other
Posted by brookway on
Anonymous
    Scholar:
  • 146 Answers
That is quite normal. What is the problem with the machine?
Posted on Oct 31, 2007
Door locked no light to say locked no washing action on hotpoint wf430
Brusheson motor will be worn. The door lock is in series with the motor so if brushes worn it interrupts the signal telling the board the door is locked. New brushes will likely be all it needs.
Oct 30, 2013 | Hotpoint WF430 Front Load Washer
My hotpoint machine wont spin
3 possible causes for machine not spinning. 1.unbalanced wash load 2.pump/filter/outlet hose blocked or partially blocked 3.carbon brushes in motor worn. have a look.
Oct 27, 2009 | Hotpoint Washing Machines
Aquarias wd 420 hotpoint
sound like motors or heaters have a short good luck.
Sep 13, 2009 | Hotpoint Aquarius WD640 Front Load...
Washes but does not spin
I AM NOT A MECHANIC, BUT IT SOUNDS LIKE YOUR MOTOR COUPLING NEEDS TO BE REPLACED.
May 13, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint WM64 keeps fusing and cutting out
it's possible that one of the carbon brushes have worn down to the bottom and it is sparking on the motor causing it to trip the fuse. It's just one possibility. Have you checked the carbon brushes are connected properly and that they have not 1) worn down and 2) that the wires are connected to them correctly.
Mar 12, 2009 | Hotpoint WMA64 Front Load Washer
Washing machines
sounds like your belt may be loose or the timer control maybe worn out
Aug 17, 2008 | Hotpoint Aquarius WD63 Front Load...
Faulty Hotpoint WMA76 washing machine
it may be 1) a connection loose at the motor 2) motor brushes are worn out 3) a pcb fault check in that order.
Feb 16, 2008 | Hotpoint First Edition WMA12 Front Load...
Hotpoint aquarius 1000 deluxe W22 washing machine
the newer type motors have carbons tht are fixed in place you would need to remove the motor and on either side will be the carbons they need to be un-screwed to be replaced
Jan 12, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint WMA34 Where to find the motor to change the brushes
DON'T FORGET TO UNPLUG THE POWER FIRST!
Remove the lid and the motor is sat to one side on top of the drum.
Oct 16, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint WMA58 Front Load Washer Logo
59 people viewed this question
Top Hotpoint Washing Machines Experts
Eric Taylor
Richard C Cohen
Richard C Cohen
Onofrio Taverna
Onofrio Taverna
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
