Montgomery wards television
I have a 1987 montgomery wards tv with no remote...the channels go to 36 and then skip to 95 - how can I gain access to channels 37-94?  It is a JSJ series A tv, and I cannot find the model type .....  my universal remote will not let me access the menu....can you help?
Posted by Goopy on
1 Related Answer
gopakumarg43
  • 76287 Answers
SOURCE: have a 1987 montgomery ward television set, want to program universal remote to the tv, how do i find the number for the tv?
Hello
I assumes that your television is Wards, and posts this solution. Setup codes for Wards TV are:
0054, 0030, 0178, 0021, 0179, 0056, 0019, 0016, 0165, 0096,
0020
These codes are with Atlas DVR/PVR 5 device Universal remote control to Wards TVs.
Posted on Feb 23, 2012
Have a 1987 montgomery ward television set, want to program universal remote to the tv, how do i find the number for the tv?
Hello
0020
Feb 23, 2012 | Televison & Video
Does anyone know the comcast remote code for a Montgomery Ward TV?
I suppose the correct code will depend the model of your Montgomery Ward TV, but ours worked using a Magnavox code (11454). Model # GNB 152 78A, manufactured in 1987, and YES, it still works!
Sep 17, 2011 | Televison & Video
I have a "Montgomery Ward
The remote it dead,usally the CPU chip it dead,because the CPU chip it control everythings on the remote.Try website like Remotes.com to buy an original tv remote.
Mar 21, 2011 | Televison & Video
How do you program the montgomery ward model number jsj12248 televsion so that you get more channels?
Hi, jsj means it`s built by sharp, you need to auto-program the set, push menu on set or remote and look through the menu settings for either auto-program or add channels , gl, video-tek
May 17, 2009 | Televison & Video
Quasar tv remote.
Sounds like you need to go to the main menu and run the automatic channel selector again. It will take note note of which channels are not in use and then skip over them when you use the channel advance. Use your remote to get into the main menu and select the "TV" submenu. Then run the auto channel select. After that's done, you can also manually choose to skip channels you don't like. I believe the channel numbers appear in green if they're to be included, and yellow if they're to be skipped. Even if a channel is skipped, you should be able to get to it anytime by punching in the number on your remote.
Jul 08, 2008 | Quasar VV-2002 20 in. TV/VCR Combo
Televison & Video Logo
63 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
